FINALLY! After months and months work....
Old Aug 28, 2013 | 12:38 PM
PapaChulos4U's Avatar
...the '93 is running and road-ready. Turns out that the metal vacuum pipes attached to the head were clogged (don't ask how) and causing the truck to surge then die.
Now I'm putting on the finishing touches, so I have a question: where is the oil pressure sender connector on the wiring harness? Isn't it supposed to be on the same line with the brown connector going to the starter? I have two wiring harnesses and neither has the white wire I see in everyone's pictures. I'm wiring up my new SR-5 cluster and need it to get the oil gauge going.
When all is said and done, I will post some pics of this truck which has been the bane and love of my life.
Old Aug 28, 2013 | 03:08 PM
Punchy's Avatar
22re?
Old Aug 28, 2013 | 05:38 PM
Originally Posted by Punchy
22re?
Yes, it's an RE. Sorry, should have mentioned that...
Old Aug 28, 2013 | 10:49 PM
wyoming9's Avatar
Red face
All right I am glad you got it figured out.
But fess up how did the lines get clogged??
Old Aug 30, 2013 | 12:36 PM
Sigh....I wish I could say it was from an AWESOME wheeling session, alas that would be lying...
I really don't know how it got clogged, but there were a LOT of dead ants in there. I think the guy that worked on it in my absence didn't do anything but keep it under a hummingbird feeder and the sugar attracted them...whatever, it's done.
Back on topic though, what color is the wire for the oil pressure sending unit? I wanna get this baby going ASAP! I gotta put in my interior though: got a whole new one from a '99 Tacoma at the junkyard (bucket seats, console, shifter, steering wheel, cruise control module) for $67. Just need this gauge to work now.
Old Aug 30, 2013 | 12:47 PM
wyoming9's Avatar
Red face
I am seeing in the haynes Yellow Black stripe
The EWD for the 92 4Runner says Yellow Blue strip
Look for a wire with the insulated spade connector.
Old Aug 30, 2013 | 07:15 PM
I have been looking for the connector, but there is none. The only thing is the wire that goes to the starter; no other wire is on that line. If I find the black and yellow wire, I will try tapping into that, but I don't see why I should have to tap into a wire that is that far away (the closest wire to the ground for the starter is the knock sensor as it sits now).
I'll take a look sometime this weekend and see what I can find...
Old Sep 2, 2013 | 04:37 PM
UPDATE: Found the wire. It was yellow with a blue stripe (green if you look at it where it blends with the yellow). Plugged it into a junkyard sensor and VIOLA! It worked! Now I have a functioning SR5 cluster!
This begs the next question, though: where's the first place I should drive when I put this thing on the road? ;-)
Old Sep 3, 2013 | 12:11 AM
wyoming9's Avatar
Red face
Gas station for a tank of fresh gas after all this time.
Then any where you like
keeping a eye on things of course!!!
icentropy
Sep 16, 2020 02:47 PM
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
trailgoat
Aug 13, 2015 05:54 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
