PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Another rough running 22re
  2. 2 replacement gas tanks failed at weld spots
  3. AFM replacement boost?
  4. 1991 Toyota pickup 3.0 Starting issues...
  5. Mounting fire extinguisher truck cap?
  6. Timing Chain Cover Cracked
  7. 1987 4runner Auto Trans acting crazy
  8. Short throw shifter kit... Marlin vs LCE vs ?
  9. Problem accessing FSM
  10. 94 toyota pickup o2 sensor
  11. 94 Toyota Pickup Head Gasket Replacement
  12. 90' 3VZE throttle body / tps / idle air control valve
  13. 92 yota almost overheats
  14. 1987 toyota pickup truck 4x4 22r no spark
  15. 93 oil pressure sending gauge wire?
  16. 92 Pickup Offer?
  17. Diagnosing a Coolant/Oil Leak
  18. 3vze Fan
  19. 86 22RE, seeking second opinion
  20. Oil leak directly under oil filter. Possible causes?
  21. My 95 22re 4wd pickup.
  22. Front Frame Crossmember Damage
  23. alternatorsx2 in hilux ln110 modell
  24. "94" 3vze Power Steering Air Control Valve
  25. Buzzing at bell housing in an 86.
  26. WTH is this thing behind the driver side kick panel?!
  27. Rear Bumpers for 86 Pickup - Plate Style?
  28. 1990 regular cab 22re + 400 small block chevy + t5
  29. Potentially blown HG on 1993
  30. Anyone know where this goes?
  31. anyone building a 2 wd street machine?
  32. Speedometer Drops to ZERO when I Signal
  33. 1987 4runner Scratched Tailgate Glass
  34. Seeing Daylight Through My Intake
  35. 1986 pickup, 22R dying after driving for 5 minutes
  36. 1995 4Runner 3VZ - almost working right...
  37. New member, new to toyota toys..bought something silly
  38. Warn Rear Bumper 89-85 ... will it fit on an 86?
  39. Transmission Identification
  40. Massive hesitation - 94 Pickup 3VZE
  41. Front Brake Repair Question
  42. TPS Part Number Help
  43. Power Windows and locks stooped working
  44. 95 runner tail window blues
  45. New Guy
  46. 93 3vze coolant fitting on block
  47. How to Make Fog Lamps Come on w/Low Beams?
  48. 93 4 Runner "snorking sound"
  49. 85 4Runner problems..... Please Help
  50. Can't Find Power Steering Leak
  51. 3.0 slaughter!!!
  52. Electric vs Manual Choke - Weber 32/36 - 1987 22R
  53. 87 22Re timing
  54. can anyone answer this simple tranny temp question for me?
  55. Replaced Knock sensor, now have knock or misfire?
  56. no spark
  57. 1st gen 4R top weatherstripping
  58. Who Makes OEM Plug Wires?
  59. 94 4Runner Auto Trans Removal HELP
  60. Very high (5k rpm) idle on start up
  61. Front end help
  62. Light bar questions
  63. 93 3.0 suddenly won't start...
  64. Need advice for a common problem
  65. 1991 Yota 4x4 wont start/died
  66. 4runner auto to manual swap questions
  67. major issue. please help
  68. Starting Problems 94sr5 4x4 3.0 pk up
  69. First Post, Need Advice on my situation
  70. power steering air control valve 93 4Runner SR5
  71. oil consumption and blue smoke
  72. Removing Old Alarm. Oh my this is bad.
  73. 86 truck will turn over but will not start
  74. Offset tires and bearing wear.
  75. 94 4Runner 4x4 auto trans problems
  76. heater core - plugged or shot?
  77. 91 4runner head removal help!
  78. 87 22r Weber 32/36 troubleshooting
  79. 2rz and 3rz info and swap info?
  80. 22re is it worth it?
  81. 22re idling problem
  82. Help! 1986 2WD pickup, timing chain screw-up!
  83. Tach sometimes indicating 0 RPM
  84. ADD vacuum question
  85. intake swap
  86. 1987 4 runner engine runs rough and rich but has power
  87. Help with fuel line?
  88. longer brake lines
  89. 4.88 or 5.29 gears?
  90. Questionable gearing help please!!
  91. 87 4Runner 22re ignition hard start
  92. How to Jump terminals
  93. Where to find a switch for dash knock out
  94. 1999 3rd Gen 4Runner TDC Help
  95. Possessed radio and clock?
  96. 3.0 issue!
  97. What is this trim called?
  98. 1988 pickup question (new to me)
  99. 1987 4runner Rear window won't go up.
  100. What radiator?
  101. Clutch pedal repairs question
  102. Replacing lower control arm bolts
  103. Rear Differential; Spins After Pinion Seal Change.
  104. 86 1 ton misses when warm
  105. Bumper mount specs
  106. Body part question
  107. 94 3.0 exhaust crossover pipe issues
  108. Cold Air Intake Box Sound 1994 22RE
  109. medium travel ifs?
  110. Question about ADD delete
  111. 94 Toyota 3.0 troubles
  112. Anyone have their ECU rebuilt?
  113. Weird brake booster thing
  114. 1993 rear leaf hangers?
  115. 1994 ac controls in a 1986??
  116. Metal coolant line around back of 22re
  117. Removing bed 93 ext cab 4wd
  118. Total chaos caddy kit gen 2
  119. 90 3.0 motor direct swap into 93?
  120. 3.0 head gaskets
  121. part ID and vacuum line
  122. Burp???
  123. Motor rebuild help
  124. Fuel issue?
  125. Rear window trim
  126. Fuel Pump /Injectors question
  127. Just found a little something
  128. 1986 Pickup - Need to remove and plug Rear Brake Lines, Need help...
  129. Speed Sensor Information - Cable ODO/Auto Trans
  130. 1990 truck 22re starts but runs rough and dies(this 1's a stumper read on)
  131. Rear axle woes - can't find one
  132. 1993 Emergency Brake
  133. 93 3VZE getting terrible MPGs
  134. Affordable, Decent Fitting Seat Covers for SR5 Seats
  135. Rebuilt 22RE Misfiring (Need Tuning Help)
  136. Starter or clutch issue???
  137. 94 22re 4WD Pickup Tape Player
  138. 86 toyota Pickup failed inspection
  139. New PS pump making noise
  140. How to test continuity KNK circuit.
  141. Toyota Pickup 3vze Noise w/video
  142. 94 sr5 4x4 3.0 troubles
  143. 22re head gasket
  144. 94 Pickup 3.0 Cooling/Idle Issues
  145. New to the truck game
  146. "88 3VZE Running Rough after VC Gasket Replacement! Please help!
  147. Help. Timing issue? Runs rough. New head gaskets
  148. 3.0VZE issue ! Please Help !
  149. A304H Trouble 1989 4Runner
  150. 1995 3VZE gas tank
  151. Bed sizing
  152. my 5 speed won't shift
  153. 1986 SSR5 Xtra Cab Restification
  154. need ideas
  155. Speed Vs. RPM question
  156. Fine tuning my 87 pickup
  157. Engine timing problems
  158. Squeaking sound from engine compartment.
  159. Transfer case blowing fluid at 70 and above.
  160. radio harness help
  161. FINALLY found the rain leak!!!!!! Now what to do?
  162. 4wd not working on 93 Toyota pickup
  163. 22R external coolant passages - why?
  164. I'm stuck trying to figure out my fuel and return system
  165. Help !!! JUST DID OIL CHANGE, TRUCK WONT RUN
  166. 1988 Engesa 4 FII toyota swap
  167. BB in "egrv to pipe" vacuum hose
  168. 89 4runner auto trans fluid change
  169. 94 4Runner problems 3vze
  170. Toyota3.0 trouble
  171. Timing
  172. 91 22r cranking issues.
  173. 1 gen 4runner rear seat cover?
  174. Can anyone ID this Dana 60 hub seal? I'll send you a six-pack
  175. 1991 3.0L blown head gasket, truck for sale
  176. Help source gas tank & parts?
  177. Transmission bolts
  178. Fresh rebuilt 86 22RE "wood" knock? VIDEO
  179. ? about failed CA smog test
  180. Best oil n filter 92 toyota 4cyl
  181. Identify this wire and harness - power window issues
  182. bad brake booster and hard to press brakes
  183. Crankshaft stuck
  184. 88 3.o engine stalls when air intake removed is this normal?
  185. Intake Manifold Issues 91 Pickup 22re
  186. '95 4runner won't start on really hot day
  187. Replacing dented/smashed body panel
  188. Spark plug question. 89 3.0 truck.
  189. 86 4runner: Battery not charging
  190. Couple little things that maybe someone can help with?
  191. 86 Fuel tank - carb vs EFI hole diameter?
  192. fast idle and horrible gas consuption after motor change
  193. Oil Leaking from bolt
  194. Transmission Question
  195. 86 22re pickup hard starting after tune up...
  196. Lets talk cold no high idle, throttle hesitation, and EGR
  197. Hunting Idle After Some Work
  198. Need some Help Please! Needing to rebuild my 4runner 22re
  199. What are these?
  200. HELP. 1993 V6 3.0 front rotors needed OEM
  201. Where to find knock sensor pigtail?
  202. 92' 3VZE Rough Idle
  203. Motor swap on a 95 4 runner
  204. Mystery Wire Engine wire connectors
  205. Recommend me a hid kit
  206. Fuel pump assembly bracket
  207. Rear window stopped working
  208. 88 REC wire loom plug -black
  209. Flat bed ideas?
  210. vf1a transfer case - requesting fill and drain plug torque settings
  211. Need help identifying IFS lift parts.
  212. Oil leak
  213. Coolant Smell
  214. Need help
  215. 93 strange "cling" noise!!
  216. Broke a timing cover bolt. Now what?
  217. afm check engine code 2 HELP!! PLEASE!
  218. 87' G292 swap options?
  219. 88' 22RE computer questions
  220. Hole in Axle Housing After Removing U Bolt- repair or replace?
  221. Headlight Issues...could it be wiring?
  222. Trouble starting in frosty weather!
  223. Stumped by significant misfire...
  224. Kayline Soft Top
  225. HELP! Lost all power in engine. Timing chain?
  226. is truck running too hot?
  227. Did I get a knock-off OEM knock sensor?
  228. 4runner blower motor suprise
  229. How important is the TPS?
  230. How much vacuum 3vze
  231. Solved my Code 52 problem!!!
  232. How do you get the timing chain sprocket on the camshaft?
  233. Turbo Exhaust Stud Stripped
  234. 94 22re wont rev up
  235. burping bottle
  236. 1988 22RE distributor timing question.
  237. 1994 Toyota 3.0 running terrible
  238. Shocks
  239. will 1100 stall torque con cause a problem in A340H
  240. 90 4runner high idle cold and hot....
  241. Replacing rocker arm studs
  242. Engine "rebuild" 22RE
  243. 92 Extra-Cab
  244. How to torque things I can't get a torque wrench on?
  245. Exhaust intake tips 94 22re
  246. 93 radio static issues
  247. Re-gearing Help!!
  248. Batteries
  249. help!!! rear wheel well plastic
  250. 86 Pickup bed and bumper project
