- 22re to 4.3 or 350 v8 swap
- Rear window not working
- What brand of radiator do I get?
- Truck gurgles after mudding
- Maf Help!! Alt. Help
- lookin for parts
- EFI swap 22r truck to 88 4runner efi parts
- Not Sure What To Do
- I am getting a new head gasket
- 87 yota 22r, runs good no power to it though
- Anyone installed a Hayden Electric Fan in 3.0?
- removing vacume lines off -road only?
- girlfriend won't drive in my truck if i lift it any higher....
- 3.0 3vze low idle after warm up
- Wheels and tires
- 3.4l Swap Questions....
- advice on lift and tires
- suspension travel 1987 toyota
- Need some advice.
- 95 4runner - heater problem
- Are 3rd Gen 4runners significantly improved over 2nd Gen?
- 95 4runner tranny ?
- Strange Tranny/ tc issue?
- Just bend me over 3.Slow
- Engine code problem and gas issues
- New Wheels Chrome 2 black (56k Warning!!!)
- Tranny Removal Writeup
- How much is my 4R worth? 1990 22RE 5spd, 4.88 gears, great condition?
- She is ticking :(
- E-brake help needed
- LPV help
- 84 pickup on ebay
- 3.0 motor build
- Helppppp!
- 3.0 opition any input?
- Lift installed... A couple problems...
- high mileage Seafoam treatment?
- showin some mussel
- Very confused now on lifting my truck...
- Would like advice on replacement seats for my 88 yota pickup...
- Another 22RE head gasket thread - with pics - help needed
- pushing an IFS toyota to its limits
- loose cable on 3.0
- 4 point
- aftermarket blinkers for ARB bumper
- new pics with muds
- O2 sensor woes
- 87 4Runner/22re racing between shifts
- gas pedal still sticks
- Advise on purchasing an '86 truck
- Sliding rear cab window?
- random dicussion on whats most important
- Need a Part identification
- black rockcrawler rims?
- tacoma rear
- What breaks the most on 2nd Gens?
- Tire time - real world experiences
- need help no spark on 3.0
- 3.4 Trans Options
- How much to rebuild a w56?
- 22RE = dead?
- '87 4runner door problems?
- swap 3vz on 2jzgte at Runner 4x4
- Problem with EGR and removal
- 1992 4Runner stolen?!?!?!?!
- Resealing a third member
- Tires, 33x12.50
- Holy MOLLE
- squeaky speedometer cable
- defeated by the ebrake cable
- 89 4Runner dies at idle....
- Fixed my clutch problems!!!
- Heavy Throttle on 3VZ help
- part number for rear shock bolt
- Clutch, tranny driveshaft squeek in Rev.?
- Push clutch in hard=Grinding&Battery drain surge?
- Timing - Suggestions?
- How can I make my truck worthy of some serious trails?
- baja racing headers
- Rims now black
- My progress and a few questions..
- Anyone know what engines bolt up to the 340H transmission?
- washer bottle motor
- Can you help me identify my oil leak?
- ISR parts
- EGR Removal Pro's and Cons
- Removeing a W56
- How many O2 sensors on 90 4runner?
- Sticking choke or EGR?
- I've got a few "what is this" pictures.
- I joined the painted rims club.
- Loud Grinding Noise From Front Left
- 3VZE Spark Plugs, Which one do you use?
- 90 4Runner Toyota Repair Manuals
- Oregon Engine Rebuilders
- help with speedometer
- New here and question (2gen Runner)
- Crap! Head Gasket Giving Up the Ghost...
- First Post! Just Got a 2nd-Gen 4Runner! Suggestions!
- Advice...
- 22re auto transfer case cooler
- 22-RE to 3.4L and 3.4L to Lexus V-8 swap question
- What's a good seat cover for a driver's seat in a '90 runner?
- Clogged cat cause of blown headgaskets?
- No 1st gear?
- weight of bench seat
- 22re problems.. help!
- Too much play in steering wheel
- '95 won't start
- 22RE(T) Wiring Help Required
- Lousy Brakes
- Adjusting front camber?
- Really BAD Gas Mileage
- When would you recommend a steering stabilizer
- knock sensor - help
- Banjo bolt size on cold start injector?
- Help! popping sound while on the gas
- Can backpressure affect gas mileage?
- why would anyone....
- Mystery vacuum line.
- Non vent wing doors and cracked window sash mount
- Good place online to get lights?
- Intake pipe
- how do you adjust the speedo?
- engine code
- High A/T oil temp
- surging idle fixed...
- 180' and a holesaw
- Ever broke a hitch?
- Anyone else ever had this noise
- Just blocked off my EGR....
- How to tell if......86 4Runner....
- '86 4Runner 22re only runs with key in "start" position
- Engine rebuild
- The Mystery Hose
- new tires, quick question
- Question on head shims?
- Running boards, keep em or loose em
- 3.0l performance build-waste of money?
- 86 4runner electrical problem
- TRD torsion bars
- 4runner sounds like a tank. WTF IS GOING ON!!!
- what is the horn ring
- how to adjust door latches?
- Herculiner Inside 4Runner
- super hot manifold
- Body Lift
- Does the time belt in a 3.0 give warning
- easylok hub?
- AHHH! How do I get my back seat out!
- anyone have a carfax hook up??
- mpg after tires and lift
- hub question
- Thinking about the 3.4 swap Have some questions though!
- 3vze cold start problem
- Newer gen Rear Tire Mount fit on first gen 4runner?
- Leveling Kit
- pics of skid plates
- 91 extra cab pin stripe?
- 1994 toyota truck
- cel codes after new tps sensor?
- Eliminating the metal windshield trim aka rust maker
- Finally, truck pics...
- 3.4 Swap '94 4Runner - 96 Taco 5vzfe
- the aisin's are on finally!
- My 3vze doing weird things
- Tow Hitches and advise(4 banger guys)
- Oil filter maddnes.....!!!!
- steering stabilizer shock
- Head Gasket Done?
- injectors leaking after new seals installed?
- 22RE Throttle Body Cleaning
- Power Steering Pulley
- How long did it take you to get your OME suspension in?
- odd noise from rear
- Is this a good deal?
- 92 fsm for free??
- A/C install issue evaporator
- rear diff replacement - questions!
- Doing 22RE HG - Have a EGR valve gasket question
- How does push starting actually work?
- New 4runner owner needing some advice!
- Code 41 symptoms?
- Hella 550
- Power steering pump pully?
- more power
- my truck pics
- Rig Bucked very hard doing 70mph
- My toyota didn't come with a lighter...is the wiring in the harness??
- 4.88 gears for toyo e-locker?
- Front Fenders on 81
- Rear Disc Swap
- Do I have the wrong shocks?
- clutch install ?s
- Faulty gas cap???
- Who is driving the big black 4Runner in Knoxville/Clinton?
- Sagging rear end
- More Newb Mod questions
- Help; Misc. Problems under the Hood 3.0
- Finally got the balls to paint my rims
- Severe coolant leak on 1991 3.0 PU
- 3vze part Id??
- 3.4 swap costs?
- 93 4runner rear window problems
- '90 3.0 "hunts" for overdrive, & engine temp is never very high. Related?
- 3vze cam pulleys
- 3.0 Vaccum Help!
- U-joint recommendation....
- Lost code light found, 90 22-RE truck
- any tips on doing a lower intake on a EFI 22RE?
- Another heater question for an 88Runner
- Smelling fuel inside truck?
- looking for new tail lights
- Rear Suspension Question
- is a pickup window regulator the same as a 4runner window regulator?
- Real Bad Vibration
- 88 4Runner charcoal canister: Purge hose.
- my new bumper, son
- Starter Keeps going after truck starts
- fuel sender/pump length
- pics of your seats
- 89-95 Truck bed demensions
- 86 4RUNNER efi not starting
- Lift ID
- Bedliner for sale
- Lift Manufacturer question for 88 yota IFS
- 4runner HU
- 1990 4 cylinder airbox question
- questions about test drive
- tranny & gear oils
- Tranny fluid 10 yrs. old
- braking vibration
- 22RE fuel pressure problem
- No heat, new TC - Water Pump?
- Besttop supertop on pickup. Looks sweet!!!
- Newbie needs info on where to money for reliability
- diagrams for a 22r carbed engine...i have no clue where anything is under the hood
- CV Axles interchangable?
- clutch won't hold pressure
- 3.0 rough at 1500 - 2000 RPM
- High Idle - All The Sudden
- Rear drive shaft disaster averted
- Seat and Wheel Swapability
- 87 Bj-70!!
- Tranny ID
- how to tell if you have a burnt valve?
- 22R rough idle
- Bad coil / Ignition control ??
- Transmission Filter change - questions
- What do i need if....????
