- Code 41/52 3VZe
- 22re coolant loss
- Crankshaft bolt help!!!!
- Ball Joint lube
- 3.0 to 22r engine swap question
- Water in intake. How screwed am I?
- What connection is this + Injector + Vacuum Related EGR Questions.
- 91 4x4 Project. "wrinkles"
- Damaged and dangling vacuum tank
- Introduction and Intermittent Start Issue - '90 SR5/MT/V6
- Brake booster vac lines dealer only ????
- Help! Not running on all cylinders.
- CEL Says too rich and too lean??
- Idle Speed Changes with Temperature
- 88 ecu question
- Ecu and harness for 3.4l swap
- Rough Idle and hissing noise problem.
- New owner of an 87 4runner - need some help!
- Pitman Arm Question
- Suspension lift kit??
- What causes a surging idle at 2rpm?
- 3.0 to 22re swap questions
- me and my new 93 tacoma with a utility bed
- Removing hub, axle spinning
- diagnose my head gasket plz
- fuel line crush gasket p/n?
- Leaky radiator masking hg leak?
- Blazeland long travle.
- 1986 Toyota 4Runner need help ASAP
- Where to get 1990 4Runner Front Parking Brake Cable?
- 3vze no spark
- Spin the tire test for gear ratio front axle
- Links for BJ spacer lift. 1991 pickup.
- Shifter removal
- 3VZE Really Slow in Higher Gears
- Knock Sensor/Intake Manifold Questions
- What Is My Pencil Pointing to?
- 90 3.0 problems
- Can this be deleted?
- Wheel offset question
- Compatible coolent temp sensor
- 93 Toyota std cab 4x4 22re fuel issues
- Cam drive gear...
- Constantly blinking CEL when reading codes
- Fan speed switch plug melted-need ASAP
- 1994 Toyota pickup automatic transmission fluid type
- Timing help!!
- A340h solenoid replacement
- A340 questions
- Swapped wheels and tires and now I hear a loud clicking!
- WILL a 22r 4x4 1985 rear diff work in a 22re 4x4 1992 rear end??
- WILL a 22r 4x4 1985 rear diff work in a 22re 4x4 1992 rear end??ear
- Cutting off rear U joint. Thoughts?
- Turbocharging A Stock 22re (BUILD)
- 22r grounds
- Oil Pan redo
- New 1986 Pickup, where to start
- Ticking noise...
- Will a 2nd gen radio bracket fit in my '88?
- Heat Slider Doesn't Work (No Heat!)
- Strange overheating issue 1992 22re, replaced just about everything!
- Swapping out rear u joint.
- Cleaned engine and killed it
- Diagnosing my 4x4 Problem 1993 3.0
- Searching for Extra Cab Cutout Conversion Mods
- Bolt Size for Secondary Air Injection
- Strongest Clutch Upgrade 86 4runner Expedition build
- 88 Pickup Parking Brake
- shifting problem 87 truck
- Rattling during exceleration
- Dead Toyota (possible starter issue?)
- 90 pickup blower problems
- 3VZE IACV ? that hasn't been asked
- 1st gen 4Runner rear window re-wire
- 87 4x4 radiator fan swap
- manual hubs came with different clutch sizes?
- Ok y'all timing help...I've looked everywhere
- Highway pinging/bucking
- 89 4Ruuner Brake Master Cylinder
- Truck Cranks but won't fire
- Bed to frame mounts?
- Hesitation to start cold
- clutch slipping...how long till it goes?
- Brake pedal goes to the floor?
- V6 Shift Kit
- Best place to purchase EGR/PVC hose/breather hose?
- Is it fine for steering stabilizer to wiggle on one end?
- EGR help
- 3VZ-E not revving past 2k
- 91 toyota
- 1993 4x4 Pickup fuel door lock clip
- New Clips for Side Panel?
- New coils are shorter than stock?
- Fuel/idle issues in the cold
- 22re hesitation/bog from idle
- Rear shudder and parking brake issues
- Thanks...
- 3VZE valve timing?
- No power
- 22RE Exhaust Crack at Collector Pipes - Common?
- Are rear shocks different sizes? Mine are.
- Infamous 22re issue!!!
- Truck shutting off
- 87 22re won't start Please HELP
- Newbie Banana :: Changed Oil, knocked off cord, truck won't start
- wont turn over power steering hose gets HOT
- Specail service campaign vo6
- Why does propellor shaft need matchmarks for removal?
- Driving with one hub locked
- now my 4runner is trying to kill me?
- New shocks to go with bj lift
- 4wd Pickup: Stock Height?? Quick Help Please
- Two piece driveline and carrier bearing
- upper radiator hose
- Has anyone ever rattle canned there truck
- Really stiff clutch
- 91 4runner, no 4wd
- my blinkers and hazards arent working
- Intermittent low rpm sputter
- 2nd gen front seats in a 1st gen T4R?
- Swapping IFS from 92
- Timing Issue / TDC / Valve adjustment
- 89 4Runner gas sender in a 86?
- 1986 pickup 22re - no spark. I have tried all I can think of to do . Please help!
- How to fix bracket lift and upper control problem?
- Replace injectors 3vze
- 22re crank sprocket breaking
- New fuse panel?
- 93 Runner rear window problems
- Can the 22R EGR Crossover plate leak oil ?
- 3VZE idle issue
- 88 rough idle and stalling
- CANBACK IS BACK!!! Soft top group buy..
- HELP transfer case stuck, no power to tires
- Looking for 1989 2.4L Exhaust manifold... or after market
- 1989 2.4L Rear wiper part number Needed, Front parking brake cable numbers here
- 3vze valve timing or intake leak?
- 3VZ-E valve adjustment shim grinding DO's & DON'Ts
- Help a Newbie: General Updating To-Do List
- 91 pickup OME leaf spring question(s)
- Rear Axle Seal/Bearing Job
- 95 4runner rear shocks
- 1986 SR5 Steering Stabilizer/Damper Issue
- Radiator fan wobble
- 1987 toyota pickup
- Hard to start with Weber 32/36
- 94 4runner manual 22re SIEZED
- 4Runner gen.2 22re 5 speed on v6 frame- need guidance
- Why did last owner plug this line?
- 89 22re no start issue
- Another failed smog question
- Performance issues
- 94 Windshield Trim - Chrome Strip!
- 93 3.0 pickup No Crank, No start, No nothing! Help!
- Quick question about 4runner seats
- Chinese flywheel from Marlin Crawler
- 1990 4Runner Intake question
- Transmission swap
- 4x4 problems
- 4runner 3vze strange starting problem
- 86 22r doing some very odd things(runs better without third cylinder??)
- How to relace transmission solenoid VIDEO
- New OSK Timing Chain Tensioner Advice
- DECK LAMP Fuse
- New Here: 22re Leaking Coolant (plz help)
- Master Cylinder block off plug size?
- Clunking Noise in 4Hi!! Help!!
- Engine mounting advice
- Dead 87 4runner
- battery draining
- 1991 toyota pickup Coils in rear Bj spacers up front
- Restoring original paint and decals on '86 4Runner?
- What is this plug??
- Dashpot problem on 22RE??
- Wheel vibration??
- loud chattering noise after Zuk Mod
- 94 t100 6 cyl No start with spark and fuel.
- o2 code being thrown when o2 is fine?
- 95 4Runner 4WD 3VZE: "4WD Selector Mode Switch/Module"??
- 22re Over-pressurized cooling system, possible blown head gasket
- 22re starts then dies immediately
- 1989 4cyl .
- 3.0 to 22re 2nd Gen 4runner
- The right stuff still gummy.
- 1990 4R 2 door none removable top
- 94 Toyota Sputtering, HELP.
- Loose ball joints on mirrors
- 22RE idle misfire and surge
- Oil pressure wire broke
- New 22re engine break in..... I have no clue!!!
- 5vzfe engine with 1994 stock transmission
- Finally
- 88 t4r grill clips...or better solution
- Crankshaft Pully Assembly Tip: Put bolt in the freezer
- 15 months and 1,800 miles since last oil change. How long do you wait?
- 1988 Pickup 4WD Front Right Knuckle Question
- Few issues with new to me rig
- Looking for disassembly manual for 1988 3vz-e
- 1987 carbureted, want to put in 22re carbureted
- Hydraulic e brake question
- Transmission identification?
- Oil pan to timing cover question.
- Hardware Help - 2002 Tacoma
- How to remove this rivet?
- 1986 22R will not start after it cools down
- V6 chain to gear drive t-case question
- no power at WOT
- Need links for panel removal
- Damn black ice
- 1994 4Runner, questions about fog lights
- Distributor drive gear question
- Chrome elimination
- 22re question
- Light bar comes up short of brackets
- Timing Cover Help
- Rear Differential issues
- Removing plenum
- Plugs
- no spark - no power at fusebox
- Misfiring 22re
- 22r Burnt Valve/Head Replacement
- How to connect these tubes??? 91 Pickup 2.4L
- 91 pickup chevy axle and springs help!!!!
- Motor mount stretch
- No more IM testing for Alaska! What performance mods can I do now?
- Major electrical issues with 22re. Bad ECU?
- Truck dies after a minute, fuel pump relay rapidly clicking..
- 95 T100 misfire, checked everything!
- Dashboard clock question
- 87 toyota dual case problems
- AC Compressor Clutch Bearing
- Busted antenna?
- 3VZE coolant leak - pass side
- Where does this connector go 22re??
- 4runner builds
- Wipers - No Int, Mist or Park
- Replacement dome light switch?
- Fast turn signal
- truck running rough when OAT below 20
- Turbo Model...To Buy or Not To Buy?
- Cold air intake
- U bolt size
- Tech help
- Ome suspension question
- Cleaner fuel injectors = lower fuel economy...?
- My truck is making this exact noise, what is it?
- 88 transmission swap
- Weber fuel bowl leaking down
- '93 22RE Crank, no start
