Can this be deleted?
Old Feb 12, 2016 | 08:13 AM
NMDesertRat's Avatar
What is this (RED ARROW AND CIRCLE)? I assume it's an A/C VSV...
Can it be deleted simply by looping the vacuum lines as illustrated with the BLUE arrows?
The black cylinder filter apparently fell off and is resulting in an audible hiss. It seems to be constantly sucking air. Probably not great without a filter.
Old Feb 12, 2016 | 08:38 AM
scope103's Avatar
Valve, Magnet 88690-89132
http://www.toyotapartsoverstock.com/...869089132.html
$18.24 -- just fix it!
Old Feb 12, 2016 | 08:51 AM
92ehatch's Avatar
You can delete it but if you use the ac then fix it. Your idle will be crap low without it and the ac running.
I also don't think it should be sucking air unless the ac is on
Old Feb 12, 2016 | 08:52 AM
But.... I don't wanna. My A/c doesn't work and I can remove the top...
Fine! I'll replace it.
Thanks, Scope!
Old Feb 12, 2016 | 09:55 AM
Right. That's why I assumed it was bad. I ordered one through toyotapartsoverstock. I'll delete it until I get it.
Calioutdoor
Feb 15, 2016 08:19 AM
conehead
Feb 7, 2016 11:30 AM
studeb
Jan 28, 2016 08:08 PM
joshik
Jan 28, 2016 07:59 PM
jkj2000
Jan 17, 2016 01:29 PM
