89 4Runner gas sender in a 86?
Old Jan 30, 2016 | 04:50 PM
GeoRoss's Avatar
I found a pristine gas tank, pump and sender today in a salvage yard. i didn't get it today because I wasn't sure it would fit in my 86.
My internet searching Kung Fu has failed me. Will these cross over?
Old Jan 30, 2016 | 11:06 PM
Terrys87's Avatar
It will work. I cant remember which plug is different on the float or fuel pump assembly that is different but I have just wired in the correct plug in the past and it works. One is a round plug and that is the one that is going to be different. The other will be a flat plug. The wiring is the same color so I just switched plugs by soldering and shrink wrapping.
You said 89 runner to 86, in your signature I am assuming you mean an 86 Runner as well. If it is an 89 runner to 86 pickup, no then they wont interchange. Pickup and Runner tanks are different.
Old Jan 31, 2016 | 05:08 AM
GeoRoss's Avatar
Thanks, that is correct an 89 4Runner tank, sender, pump, float going into an 86 4Runner..
Thanks again.
kawazx636
Mar 23, 2023 09:37 AM
toyturtle
Jan 27, 2016 12:00 AM
91mudrunner
Jan 10, 2016 12:36 PM
MudHippy
Jan 2, 2016 04:52 PM
