89 4Runner gas sender in a 86?
I found a pristine gas tank, pump and sender today in a salvage yard. i didn't get it today because I wasn't sure it would fit in my 86.
My internet searching Kung Fu has failed me. Will these cross over?
It will work. I cant remember which plug is different on the float or fuel pump assembly that is different but I have just wired in the correct plug in the past and it works. One is a round plug and that is the one that is going to be different. The other will be a flat plug. The wiring is the same color so I just switched plugs by soldering and shrink wrapping.
You said 89 runner to 86, in your signature I am assuming you mean an 86 Runner as well. If it is an 89 runner to 86 pickup, no then they wont interchange. Pickup and Runner tanks are different.
kawazx636
Mar 23, 2023 09:37 AM
