3.0 to 22re 2nd Gen 4runner
Old Jan 21, 2016 | 10:44 AM
AKrambler's Avatar
Before ya'll start yelling at me hear me out.
I have a 93 T4R with a good running 22re 5speed, problem is the body is shot. I have a opportunity to but a very clean 92 T4R with a blown 3.0. I have been searching through several forums with no luck on how hard would it be to swap the 22re for the 3.0? I know the drivetran and motor mounts, but how does the wiring go?
Before you start telling me to swap a 2/3rz or a 5vz its not in the budget. help would be very appreciated.
Old Jan 21, 2016 | 01:00 PM
wyoming9's Avatar
Red face
To do the wiring the easy way is get copies of both vehicles Toyota Electrical Wiring Diagrams
I have no clue how I would do it any other way.
Then it is a matter of merging the engine harness with ECU to the vehicle.
Not hard just time consuming to repin the plugs
Old Jan 21, 2016 | 01:15 PM
highonpottery's Avatar
personally i cannot warrant sticking a less powerful engine in my rig. if I'm spending my energy, time and money on something it's going to be an upgrade not a downgrade.
in regards to your build - definitely have the wiring diagrams for both rigs. I would also suggest you start reading up in build threads where the person swapped out their 22re for something else, like a 5vze. Since it's the opposite of what you're doing, it may clear up a lot of questions about what you need to focus on.
Old Jan 21, 2016 | 01:26 PM
AKrambler's Avatar
Thanks for the responses I will look into finding the appropriate wiring diagrams.
Dont get me wrong I would love to swap a 2/3rz 5vz or even a TDI diesel but living in ak all of them are few and far between when they do pop up on CL everyone wants a pretty penny for something with 300k miles on it. The last 2rz I saw had 275k and the guy wanted 2k for just the engine with no wiring harness.
Old Jan 21, 2016 | 01:32 PM
Terrys87's Avatar
I have swapped wiring harnesses on the previous generation of trucks. If I had both of those runners and was determined to do the 3.0-22re, I would not hesitate. You already mentioned the motor mounts, I am not sure of the radiator, cross member and drive shafts.
From my experience you will need to swap all the harnesses from bumper to bumper. Even the gas tank/tail light harness. I would bet Toyota has even changed them. You will need to remove the dash, rear panels, and inner fenders, basically you will strip it down to a shell.
Toyota is notorious on changing something on everything. I have even had to swap out wiper motors. Dont try to piece it together from a different year truck. Get all the parts off of the same donor truck which you already have access to.
Time wise
40 hours just to pull both harnesses out of the trucks and install it in one truck.
10 hours to swap transmissions.
8 hours to swap motors.
To remove the dash on a 89-95 truck start on the passenger side and work your way to the drivers side. This thread https://www.yotatech.com/forums/f116...4-88-a-278925/ will have a lot of similarities to what you are going to be doing and give you and idea of what you are going to run into.
Depending on how well you know your generation of truck and other issues that are going to come up, I would expect more time then what I listed above.
Old Jan 21, 2016 | 03:25 PM
Which is the main reason why I'm gonna go 1uz when the time comes. Can get a used Lexus for $1000 or less, with less than 200k on the engine pretty much any day of the year on CL in my area, but a beater Tacoma is made of unobtanium and is priced at $5k
Old Jan 21, 2016 | 04:32 PM
muddpigg's Avatar
Terry, hit the nail on the head IMHO. Shoot you have like all the parts for a full swap.
Old Jan 21, 2016 | 04:33 PM
muddpigg's Avatar
Both are same gen truck.
Old Jan 22, 2016 | 12:01 AM
wyoming9's Avatar
Red face
Well yes one can swap out all the harnesses on the entire vehicle.
Being the OP is up North it may take months to find the complete harness.
Myself I am Lazy I will take the repinnig of a few wires over swapping the complete vehicle harness.
After all the person doing it is doing the work.
Old Jan 22, 2016 | 01:07 PM
muddpigg's Avatar
However you do it. Get-r-done, nuffsaid
Old Jan 25, 2016 | 11:46 AM
AKrambler's Avatar
I went and looked at the 4runner and it ended up having more cancer than the one I have now. But on the bright side the guy had a rolled 2nd gen with only 50k on the clock. I struck up a deal with him im getting both rear quarters and a 85 solid axle for only a generator. summers coming fast so i probably wont tackle sheet metal until next winter. But I do want to do a low slung SAS before summer. Be on the watch for a build thread. Thanks again for the tech info!
tj884Rdlx
12
Jun 18, 2016 04:19 PM
kanyonkritter
Nov 6, 2015 07:18 AM
Joa
10
Nov 5, 2015 10:53 PM
shaunt
Oct 27, 2015 10:04 AM
