22re head gasket
Old Nov 2, 2015 | 07:32 PM
kanyonkritter's Avatar
22re head gasket
So whilst rebuilding my 22re I was looking around in my FSM for the torque values for the crank pulley bolt and cam shaft timing gear bolt when it dawned on me that for some stupid dyslexic reason I set my head bolts to 85ft/lbs and not 58ft/lbsam I going to be okay loosening and then 're-torquing the head bolts or did I just trash a head gasket?
Old Nov 2, 2015 | 10:27 PM
Terrys87's Avatar
Toyota updated their head bolt torque to 6? pounds, I keep forgetting the new specifications so that puts you around 15 foot pounds over. Your torque wrench is bound to have some leeway in accuracy. If it was me I would go ahead and leave it as it is.
Old Nov 2, 2015 | 11:26 PM
wyoming9's Avatar
Red face
I also would just leave it alone.
why pull it all apart to replace the head gasket.
Old Nov 3, 2015 | 12:15 AM
Well it's still on the engine stand...it wouldn't be much to to pull the head. So does this mean whenever you change a cam in a 22re you have to replace the head gasket?
Old Nov 3, 2015 | 01:47 AM
Terrys87's Avatar
I seen where someone on here ratchet strapped a head down to change a cam and had good luck with it. I too tried the ratchet strap and head gasket is holding up. The correct way would be to replace it but I have seen it done and would do the same thing again if I had to.
Old Nov 6, 2015 | 07:18 AM
krusty_45's Avatar
If you didnt start to strip any holes out when you were torquing i would just leave it be. Especially since you haven't even ran it yet and its a brand new head gasket. They will let loose a little bit after heat cycles. When you go in to do valve adjustments, just hit the head bolts again and make sure they are at the minimum torque (whatever you decide 58lbs or the updated)
Corvoid
Dec 11, 2015 11:21 AM
JUICE222
Oct 13, 2015 08:50 AM
EVars
Oct 6, 2015 04:04 AM
tylermx71
Sep 29, 2015 08:49 PM
Tacoma1313
Aug 21, 2015 10:10 AM
