PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266
  1. Front mount hitch kit?
  2. Weber or Megasquirt opinions
  3. Help: 1993 T100, 4wd, 5spd manual trans.
  4. 92’ pickup w/ a 3vze desperate troubleshooting
  5. 1994 22RE Dead Again ! - See Video
  6. T-case spring mystery!
  7. 1990 22re thermostat Jiggler?
  8. 92 pick up not starting
  9. What is white thermal stuff on expansion valve sensor?
  10. 1986 22re spark plug gap?
  11. Low Compression on Re-build
  12. 1st Gen 4Runner wrapped with 3M
  13. Oil Leak
  14. R150f shifter shake/vibration in 3rd gear only, any input?
  15. Dual Steering Stabilizers
  16. Gator Turd
  17. Engine will crank, but wont start
  18. Distributor will not turn
  19. Help removing upper control arm
  20. is an engine rebuild worth it at this point?
  21. 1990 4 runner 3.0 problems.
  22. 1999 3.0 problems.
  23. 88 fuel pump....
  24. 1992 Toyota pickup Extra Cab Om617 and auto to manual swap
  25. replacement fuel line kit?
  26. Help Identifying vacuum components/lines
  27. Need help aligning transmission bolt holes with engine
  28. How to Remove Evaporator in 86 4rnr?
  29. 4Runner rear window easy custom circuit
  30. Hissing sound seeming to come from inside 32/36 weber carb (22r)
  31. Chinese Aisin choke staying on
  32. Value of an 87 Pickup Deluxe Long Bed 4x4
  33. Danger in holey air filter?
  34. 22RE AC idler and Power Steering Idler, original/aftermarket/something else
  35. Drum brake chatter/rattling after overhaul
  36. ‘88 22re questions (vaccum/connector/egr related)
  37. 3vze Rough Idle!
  38. Aftermarket steering wheel help 86 PU
  39. Side Windows
  40. Part Name/Number Help
  41. Need help with 90 4runner
  42. 1991 Toyota Pickup- Hurricanes
  43. 22re head gasket?
  44. Center Console
  45. Remove Side Panel Fuse Box 1995 T100
  46. Help with where to start: error codes and O2/AFM
  47. 86 Toyota Pickup---idling high/low back and forth then....
  48. 22rte megasquirt bad ignitor????
  49. Need help- brakes!
  50. 1/4" wheel spacers....
  51. 1994 4runner 3.0L 3VZE engine code 71 throttle port E no vacuum at 3500 RPM
  52. Trailer Brake wiring - Cold side brake wire, 1994 4runner
  53. Pulling 22re, disconnecting tranny
  54. Thoughts on replacing studs with bolts
  55. 10 AMP Fuse Blown
  56. 1992 4Runner - Wiper Switch Issues
  57. 3vze overheating uphill after installing 3 core rad
  58. What glue to stick this floor mat back down?
  59. Speedometer issue!
  60. What is this bar called?
  61. 93 toyota pickup A/C compressor runs all the time when I turn on the fan blower.
  62. 3vze Troubles
  63. True Cold Air Intake
  64. High Idle
  65. 89 Under Body Coating
  66. 1993 22RE ac question
  67. Lock Trouble
  68. 87 pickup is dumping fuel and runs like garbage
  69. Help with trouble shooting a 95 3.0vz-e
  70. 87 Pickup has both a mechanical and electrical fuel pump - Wont turn on
  71. Vibration that I can not find, what have I not already done? HELP!
  72. Engine swap
  73. 22re, pulling a bare engine block, hone vs bore, looking for info, tips, advice
  74. How did sarah get from LA to NY?
  75. Best support for rear end 86 long bed 2x4
  76. Where to get a Power Sunroof Switch Cover for1990 Toyota 4Runner
  77. In need of a gearbox for 91 pickup , manual steering. In Greensboro NC.
  78. Battery light on and arrow shows max voltage?
  79. Oil deflector in rear axle tube.
  80. 94 Power steering I've tried everything
  81. Cylinder Head Torque error
  82. Erratic idle
  83. AC Kits AC Install Help
  84. Front Turn Signals and hazard not working
  85. The truck keeps dying even after new battery installed
  86. The truck keeps dying even after new battery installed
  87. 22re expert in L A
  88. installing chrome windshield trim
  89. 86 4Runner Turbo ECU wiring question
  90. 94 t4r won’t shift into drive after cruise control?!?!
  91. 1991 Pickup Build
  92. 87 22R 2wd Automatic Wiring Issue
  93. Motor swap help
  94. 1st Gen 4Runner - Door Carpet Replacement
  95. 86 22RE pickup new alternator/battery no charge???
  96. Just bought '86 4Runner, starts for a second then dies
  97. Rear Sway Bar Replacement
  98. Locked out! 1988 Toyota pickup
  99. Short in brake wiring, tell me if I'm diagnosing correctly
  100. 3VZ blowing cam plugs
  101. New to me 91 EC
  102. 93 Toyota pickup won’t start
  103. Rough Idle with Brakes
  104. '87 Pickup 22r - Carburetor beyond repair - suitable California replacement?
  105. Engine code 13 , 22 ; 94’ 2WD 22RE Toyota Pickup
  106. What’s my 88 4wd ext cab worth
  107. Grille swap
  108. Engine install help!
  109. 1990 4Runner 4wd issue
  110. Fuel pump not pumping with FP and B+ Jumped (1993 22RE 4x4 5Speed Ext. Cab)
  111. '89 4Runner Passenger door with double interior latches won't open.
  112. 22re 4speed manual transmission oil level?
  113. '86 4runner idle screw all the way in, high idle.
  114. 94 4Runner differential frame mounts
  115. new bumper / grille
  116. cracked muffler at inlet
  117. 87 4runner Down on Power
  118. Transfer Case Woes
  119. 94 4Runner 2wd to 4WD conversion
  120. 1991 Swamp Donkey Build
  121. 3vz-e valves
  122. 22RE Inner Fender Replacement
  123. Circuit Opening Relay Kill Switch
  124. AC Line anyone?
  125. 1987 Pickup AC Compressor Manifold/Muffler
  126. Toyota 3VZ - strangest spark issue ever?
  127. Ironman foam cell shocks?
  128. fuel pump cushion needed
  129. Xtra Cab Windows - Convert to POWER Windows
  130. 1991 Pickup Power Steering Gearbox Valve Assembly Adjustment Nut Repair
  131. 22re 4 speed manual transmission oil change?
  132. LC Engineering Short Shifter Leak Question
  133. Toyota 1993 pickup loud sound when braking
  134. Ac
  135. Holy crap I almost blew it up!
  136. R150f replacement 2nd gear?
  137. 87 4runner xfer case tail shaft bearing
  138. CEL on but cannot pull codes???
  139. Cab Fusebox/cluster/wiring Burned down
  140. CA smog evap failure
  141. Tow dolly and 2wd Manual Transmission Yota
  142. Fuel not getting to the injectors...
  143. speedometer cable issue
  144. Hard to find single weight oil
  145. Is this a good price? 1993 4x4 5 Speed
  146. Oof... Rear shock mount bracket/washer blow-out. Time to learn how to weld?
  147. 1987 Toyota Pickup Charging Problem + Charge Light Indicator
  148. Front suspension
  149. Remflex Header Gasket
  150. 90 4runner 3vze engine vacuum hoses
  151. Stuck in 4LO.
  152. swapping rear drums and back plate w/ newer axles
  153. Steering gear rebuild/ socket size worm
  154. Power steering knocks when driving straight
  155. Engine shaking at idle, low power on hills, CEL code 12.
  156. 4wd swap from 2wd
  157. Wants to run hot
  158. Checking RPM with multimeter?
  159. How to keep little plastic doors closed?!?
  160. Good bumpers in Canada?
  161. 2nd Gen 4runner $19,250
  162. Gas milage
  163. Seeking advice on suspension upgrade/lift for 94 4x4 Pickup
  164. Advice on Refurbishing an A/C system - 1986 Pickup
  165. 95" 4runer 3.0l Lacks power during warm up.
  166. Carpet Kits
  167. Vancouver to Guatemala
  168. help with the purchase of the timing belt I was quoted 2 models gates tck240a and tc
  169. Drop drag link hitting springs after lift question
  170. Bumpers with 2in receiver hitch built in
  171. Hannemann Fiberglass body parts?
  172. 1990 3.0 3vz overcharging
  173. Power windows in the pickup!
  174. 95 4runner 3.4 auto. trans. 4x4
  175. 1995 2nd gen torsion bar mount broken
  176. 92 22re pickup wíth añ affliction, is there a doc in the house?
  177. O-rings in headgasket kit
  178. What vinyl patch did you use on your driver's seat?
  179. Idle issues
  180. Does anyone know if some 1986's were shipped without
  181. Speedometer and Trip Odometer don't seem to match
  182. 95 4X4 Ball joint spacer question
  183. Dual case problems
  184. 90 toyota wont go forward
  185. Wtb 1st gen 4runner rollbar
  186. Can't find a 2wd strut rod mount 86 pickup
  187. ac compressor not compressing
  188. 1988 4 Runner 3.0 no start
  189. Weber 38 Throttle Linkage
  190. New Fenders - Metal or Fiber?
  191. Rebuilding 1985 Solid Axle Questions!
  192. Is this a bad crack on the intake hose?
  193. Drum brake adjustment 1992 22re question
  194. Brake Line Stolen, Looking for the Part...
  195. Anybody make a replacement wiring harness?
  196. Help! oil pressure gauge
  197. Anyone else with lots of miles on 22RE with no oil burning or loss?
  198. Idles like crap, runs great
  199. Engine idling but won't stay running!
  200. Curious: 4WD switch in MFI diagram
  201. New North American Owner Help Hilux Surf 2L-TE
  202. Solid Rear Window for Xtra Cab 2nd Gens?
  203. Front Hub/Spindle with ABS??
  204. How to remove the little spots on the rear side glass?
  205. Handy homeboys hokey homemade hood helper
  206. 22re overheated, cranks but wont fire up
  207. 3vze died suddenly then no start (no spark)
  208. My new to me '86 pickup is finally running right!
  209. Replacing idler arm on 93 2wd pickup. Which parts and which tool?
  210. Heater core by pass
  211. Cancel heater core on 1994 4Runner
  212. New to me 1990 T4R, several questions
  213. Oil GL4 or GL5?
  214. California differences
  215. Ignition wire separators/retainer
  216. Engine replacement compatibility
  217. Power steering air hoses
  218. 88 Cab Swap
  219. 22re crankshaft oil galley plugs
  220. New PS pump - PS is now garbage!
  221. Embarrassing Story... I need help
  222. Supercharged 5VZ Swap to 91 pickup
  223. Anyone with POR 15 regrets?
  224. You might know someone?
  225. Receiving Hitch for 86 4Runner
  226. What does this connector / sensor do ?
  227. Power steering shaft leaking
  228. Seperating hub from rotor?
  229. 4 runner dies out of nowhere when driving
  230. Runs better with vafm unplugged
  231. 1994 Pickup signal and emergency lights
  232. Blown head gasket?
  233. Help needed in getting 22re engine manual
  234. 1986 22r Turbo Called Old Yeller
  235. Tonka Toy Build
  236. Help! Brake booster or brake booster check valve?
  237. Replaced both control arm bushings at same time - truck drops to the ground.
  238. 1994 4Runner rear window fix
  239. R150 counter shaft C-clip
  240. No start
  241. On the side of the road again
  242. Loose parking pull brake. (new member)
  243. Is this a head gasket leak? (with pics)
  244. 86 solid axle 4runner
  245. help 2nd gen 4runner clunking noise
  246. Crank, fail to start '87 4runner.....
  247. Issues caused by missing gas cap?
  248. Give up, need help 93 pickup 22re 2wd
  249. 1994 Toyota Pick 22RE Automatic 2 wheel drive
  250. ARE DCU on a Toyota Pickup
