88 Cab Swap
Old Apr 17, 2021 | 08:49 AM
Manny408's Avatar
88 Cab Swap
Hi All,
I have an 88 standard cab 2wd, and I'm considering swapping it with an xtra cab. Am I crazy? I currently have a 6' bed, I assume I'll need to swap the bed to make it all work? What kind of work would I be getting myself into?
Thanks!
Old Apr 17, 2021 | 11:26 AM
irab88's Avatar
The frame is different. You'd be good up to the front B-pillar, but everything after that would misalign. Oh, and 2wd to 4? that's another frame difference.
Not saying it can't be done, but probably best to keep looking for a replacement cab the same as what you have.
Old Apr 17, 2021 | 12:32 PM
Manny408's Avatar
Thank you!
Yeah I figured it wouldn't be as easy as I thought. Sounds good, I'll keep that in mind. Thanks again!
Old Apr 22, 2021 | 05:07 AM
Dr Phat's Avatar
I thought the frames were roughly the same after 85 between 4WD and 2WD?
But seconded, either way this is not a direct swap.
oldmansimek
Feb 13, 2012 04:37 AM
ffryno13
Mar 31, 2009 04:04 PM
rdlsz24
May 26, 2008 04:29 PM
FORCE FED DUB
Jun 30, 2007 04:13 PM
dixieduck
Oct 18, 2006 06:48 PM
