Power steering shaft leaking
Old Apr 12, 2021 | 04:19 PM
joestox's Avatar
I've got '94 4runner 3vze 4WD A/T
After a exhaustive search for my power steering leak using UV dye and duct taping little cup shapes under likely leak points I found that the leak is coming from what looks like the bearing for the main shaft - right behind the PS pulley. I just bought this pump from Oreilly's and its annoying that its leaking since I never touched the shaft or bearing - it came pre installed. What are my options? Is it possible to fix this leaky bearing/shaft with this seal kit?
I'm a little nervous to open up the pump - should I be? Has anyone done this before and got tips?
Old Apr 12, 2021 | 09:12 PM
az4x4runner's Avatar
If you just got the pump from O'Reilly, I would see about having them do a warranty exchange. Most of them have lifetime warranties.
odddon
Feb 25, 2015 01:45 PM
85 FF / medic
Oct 31, 2012 04:09 PM
slothman
Dec 18, 2008 11:13 AM
n4ynu1010
Oct 1, 2007 05:48 PM
