real bad steering box leak
Old Oct 31, 2012 | 12:46 PM
85 FF / medic's Avatar
Hi guys, I have hi steer with hydro assist. I went wheeling and had to drive it back to a buddies house to get back to my trailer. On the way home the power steering pump got real loud. Found a massive leak at the input shaft. It is coming from under the shaft and just running out. Is there a seal behind that shaft I get to without tearing the box down and rebuilding it? Thank you!
Old Oct 31, 2012 | 03:35 PM
Staceman1's Avatar
I'm hoping that you have the older style IFS box so that the input shaft cover can be removed and a new seal tapped in it. Everything you need is here:
http://www.4x4wire.com/forums/showfl...v=#Post1103788
Old Oct 31, 2012 | 04:09 PM
I think I do.... I got it from a yard online. It looks like the cover should come off once the shaft is popped off and use a hammer and small chissel to remove the cover. Thank you!
Brian
andrewtexas123
Jul 14, 2015 04:29 AM
jakebarrett
Jul 10, 2015 07:15 PM
crashburnoveride
Jul 10, 2015 06:39 AM
Avenged
Jul 9, 2015 07:55 AM
