1994 4Runner rear window fix
Old Apr 8, 2021 | 09:45 AM
mrpizz24's Avatar
Exclamation 1994 4Runner rear window fix
Hello,
I'm seeking some help with a rear window issue I'm having with my1994 Toyota 4Runner. I bought it after it was involved in a minor accident in which it was rear ended. I put on a new tailgate and rear bumper. Since replacing the tailgate, the window switch near the center console with roll the window up, but not down. I am able to roll the window up and down using the key at the tailgate with no issues whatsoever. I've tested the motor using a 12V battery and it works just fine. I've made sure the rear wiper is seated correctly as well. My 4Runner has electric windows and the 'Window Lock' button on the driver side door is not engaged. I'm guessing it may be the switch in the center console is bad, but I don't know how to test it and a new switch is about $50 on Ebay. Anyone have any ideas? Thanks so much in advance! Matt
Old Apr 8, 2021 | 09:55 AM
5 Fists's Avatar
I would start by taking that console switch apart and cleaning the contacts, it could just be dirty and corroded inside. If that doesn't do it then you can start tracing wiring to find the issue. Start with the easiest first though.
Old Apr 8, 2021 | 09:57 AM
SomedayJ's Avatar
It's not the same truck model/rear window switch, but maybe you have the same problem, dirty contacts:
https://www.yotatech.com/forums/f116...roblem-299803/
Old Apr 8, 2021 | 11:56 AM
mrpizz24's Avatar
You guys rock! I pulled the switch apart, cleaned the contacts with some rubbing alcohol and BOOM! Window rolls up and down now. Thanks so much!
Old Apr 9, 2021 | 07:47 AM
87-4runner's Avatar
Good deal, thanks for posting your outcome.
Kody Ziegler
Jul 10, 2012 06:21 PM
andlours
Dec 9, 2011 05:21 PM
BC4runner88
Jul 1, 2011 11:28 PM
tessier88
Sep 18, 2010 03:34 AM
ToyYoda
Oct 29, 2009 06:40 AM
