PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 [125] 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Broken Leaf Spring ***PICS***
  2. Pictures of OEM engine bay
  3. walking in 4xa H/L at all speeds
  4. Check connector for codes
  5. Fuel tank drain plug.
  6. Fuel tank compatabilty..
  7. Engine cranks, not starting
  8. 1991 4 Runner Rear Brake Actuator
  9. in rpm no power?
  10. Did engine swap on 91 to 93 won't start no spark.
  11. Rough cold start 22re
  12. Fuel Pressure Gauge.
  13. problems with body lift install
  14. Strong fuel in cab and engine bay - 89 Pickup 3.0
  15. the rpms on a 91 4runner v6 5spd
  16. 91 Pickup V6 Fuel Pump compatibility
  17. Quiet 3vz 4R - can it be done?
  18. 86 4runner transmission question
  19. After fire 86 22r
  20. torqflow electric fan
  21. 22r snorkel pics
  22. Back With a new rig:1989 Toyota 4x4 Single Cab Short Bed
  23. How to Stop Exhaust leak w/ Band Clamps?
  24. irab88's battery/intake swap
  25. Blown Brake Line HELP With Part #'s !
  26. Constant Knock Sensor Code
  27. valve adjustment right up.
  28. Camshaft and Gear question.
  29. Transmission type with pic
  30. 1987 4runner no start
  31. 92 22re afm or fuel prob?
  32. Fan switch replacement
  33. Transfer case lift? Your ideas.
  34. LED dashlight
  35. Help! Lack of power 3VZE
  36. 88 4runner brake problems
  37. upper coolant hose help, v6 95 4runner
  38. Fuel leak near tank.
  39. new stop light switch-still no brake lights
  40. 22re oil pan removal (without body lift)
  41. Puttin in a New Motor
  42. motor swap finished.. now 4x4 problems... help plz
  43. tranny noise, commen?
  44. lucas atf any good??? any suggestion?
  45. 94 pickup v6 (vaccum hoses)???
  46. Rebuild Question
  47. I am overheating now.
  48. 88 22re Bogs at WOT
  49. Found a coolant leak need help identifying part
  50. valve spring keeper fell into the unknown
  51. Differential R&P swap?
  52. W56 bearing numbers
  53. pressure metering valve
  54. Height difference after new rear shocks and springs VZN130
  55. backfiring
  56. Door Hinges
  57. rattling noise while driving 92 4x4 auto 4runner
  58. I need torque specs
  59. A/T shifts hard until warm
  60. 85 4Runner 22RE Engine Problems
  61. 22r can i use carburated in a fuel injection
  62. Manual to Auto Trans Swap
  63. Helppp!!! Removing my crankshaft pulley!
  64. diff swap
  65. Code 12 and 25 diagnostic NEED HELP ASAP!!!!!!!!
  66. Presumeably a 80ish 4Runner UP/DOWN antenna switch.
  67. White Smoke but no milkshake????
  68. Transfer case / transmission
  69. Shifters Rubbing?
  70. lift springs
  71. Need tranny help with 1990 toyota pickup 3vze
  72. A big thank you to yotatech! Valves still click
  73. Shift console!
  74. double din in 89 ext cab truck?
  75. How to fix a messed up head bolt?
  76. A/C fuse blown
  77. yukon gear 4:88 install
  78. Add Deaver springs to stock leaf pack?
  79. TVV, what does it do, can I cap em off?
  80. 92 Hood on 95 4Runner?
  81. Vibration somewhere
  82. tranny fluid?
  83. New to yota tech
  84. Headlights,go on/off??
  85. Suspension issue
  86. carb to efi afm issue help!
  87. Valve Lash 3VZE
  88. No Power Steering..... no leaks either......
  89. More Trucks, More Problems, Hopefully More Help
  90. Burning Coolant HELP!
  91. Anyone who's worked on their TPS, Q's for ya
  92. Code 12 and 25 diagnostic NEED HELP ASAP!!!!!!!!
  93. Will an '86 2WD truck body mount on a '88 4WD frame?
  94. Roof rack on a 3rd gen Extra Cab?
  95. high RPM hesitation
  96. 3VZ to 22RE Swap
  97. Check engine light after engine revved
  98. Quick question about rear disc brake conversion
  99. First time poster 22re issue with starting
  100. 22re rough idle, timing drifts
  101. Engine stalling then won't start... seems like lack of fuel
  102. timing adjustment procedure according to FSM
  103. Broken Clutch hard line
  104. timing guides / oil pressure / noises / yuck /etc
  105. 22re knocking
  106. Can someone tell me if i'm ordering the right part? (weatherstripping)
  107. 1992 toyota pickup 22re fuel dampner
  108. mysterious TB-20 Turbo
  109. had enough of 3.slow
  110. question on a 91 4runner
  111. rear leaf bushing trouble... cannot find some that work!
  112. engine light diagnoses
  113. Throttle Control Cables
  114. Is my throttle position sensor on backwards?
  115. Weatherstripping of 1990 pickup
  116. Drive Shaft Tube Size
  117. Tcase front Output Bearing
  118. what was my stock height?
  119. valve seal replacement? 22r
  120. More 22r carb issues
  121. Coolant sensor connector wiring
  122. Are there vacuum lines that affect shifting?
  123. 86 pickup smog failed, please help. Did not pass NO
  124. What to use to coat flywheel?
  125. 86 2wd transmission chatter
  126. adjusted TPS, now erratic idle.
  127. What is this cable on my throttle body?
  128. Trying to put a `94 A340H into a `90: how do I convert the speedometer?
  129. TPS new install
  130. Engine overheating/ tick 1990 Toyota Hilux v6
  131. How to drop oil pan on a '90 v6 4runner
  132. Bogging after tune-
  133. Crankshaft Bolt
  134. Need quick timing chain verification
  135. tacoma tonneau on my 86?
  136. steering gear woes
  137. 4 inch rough country lift need ideas for a better rear setup!
  138. Knock sensor relocation
  139. 1994 Pickup, T-100, 4Runner Mirrors Interchangeable?
  140. v6 3rd member question
  141. Shocks question
  142. New radiator hoses, new thermostat, STILL overheats
  143. 22re Engine will not stay runing
  144. Roof rack mounting question
  145. Wiper Upgrades?
  146. Truck Bed ToolBox, What do you use?
  147. T-case compatibility
  148. garvin wilderness roof rack install..
  149. clutch problem after swimming
  150. ISR too hot!
  151. Engine Noise, 3.0. Rod? Exhaust? engine mount?
  152. 3vze exhaust
  153. 1988 3vze 4runner w/ '91 engine, need clues
  154. cracked dashboard
  155. 3.0 headache
  156. trouble starting
  157. Odd electrical issue
  158. Fuel Pump housing
  159. Boosted7's new 2jz Truck crash restoration
  160. Battery warning light
  161. stock toyota p/u 2wd height? (measured)
  162. 22re electrical nightmare
  163. Cold Start Injector / ECT / hard warm start
  164. TPS/ O2 sensor help!!!!!
  165. HELP with a bolt!
  166. 4sp auto o/d 2wd yota rebuild questions A43D
  167. No Rear Sound
  168. Any one know what this wire is for?
  169. replacing fenders
  170. Code 71, 41, and terrible accleration
  171. Fuel Regulator ticking sound
  172. plug gap out of the box
  173. '87 P/U Driver Side Drive Shaft Removal
  174. wireing issues
  175. Black Push Bar!!
  176. Check engine light--off then on then off...
  177. shifter bushing problem
  178. 4 bbl on a yota?
  179. Opinions on getting replacement coil springs from Napa
  180. starter contact replacement
  181. Alternator pigtail woes - PICS -
  182. valve lash woes, and other q's
  183. 3.0 V6 Troubleshooting
  184. Timing and tsp ?
  185. Radio problem: '87 4Runner install issues
  186. My check engine light just came on...
  187. Bumper swap
  188. 1995 3.0 blown head gasket rebuild trouble shooting help needed
  189. where is the squealing coming from!!?
  190. Rusty/Clogged water canister near oil pump.
  191. Intermittent hesitation with cel flash
  192. 3.0 problem no power
  193. Oil pressure problem?
  194. Starting problems back!
  195. Need PN for Upper Rad Hose Housing gasket?
  196. Hub centric or not? Help with new rims?
  197. Using "block seal" oil starved the engine
  198. 1986 Toyota single cab subwoofer box
  199. whats is this? 2nd Gen 4runner engine
  200. vibration in all driving situations
  201. Headgasket 101 and discussion 22R/22RE
  202. brake issues with 2nd gen pickup.
  203. 3VZ Ignition Issues
  204. Power Steering Pump Leak
  205. tie rod end question???
  206. 90 22re wont start
  207. quality of ebay side mirrors
  208. 22re timing cover bolt torque Q's
  209. BAD gas MPG!!
  210. 86 4runner flange yoke
  211. 87 pickup - paint project completed!
  212. shackle issue or Pull a rear leaf?
  213. Weird Electrical Problem...HELP!
  214. 4runner and pickup front clip differences?
  215. Painted Wheels
  216. 91 3.slow ruff start up
  217. Cause of 5th gear whine?
  218. Digital clock placement
  219. Best method 22re valve seals
  220. AAL from 88 4Runner to 1994 pick up
  221. Help can't find torque specs
  222. overdrive relay clicking and overdrive not working
  223. Mystery misfire. Any advice appreciated. Contemplating jumping off cliff...
  224. '86 4runner sighs after shutdown
  225. Intermittent rough idle upon starting, EGR related?
  226. Catalytic converter
  227. 1992 3vze oil cooler
  228. valve noise
  229. Drive shaft differences
  230. How much R-134a to use for retrofit?
  231. rocker shaft assembly (22re)
  232. and its still over heating... water pump?
  233. Monroe Reflex or Rancho 5300?
  234. Fuel Injector Rubber Grommet
  235. back door light
  236. TPS adjustment experts I need your help.
  237. noisy compression spring for steering shaft
  238. How to tell if a used rear end is good
  239. Install pics - TRD Supercharger on top of '89 3.0
  240. Does your 3VZE "tick"?
  241. Valve setting
  242. Help please - always in 4wd
  243. 22RE won't rev past 3k
  244. trans help 89 4x4 ex cab 22re 5 speed
  245. Vacuum Leak Problem Areas 22re
  246. 3VZE timing marks
  247. Battery dead, ticking in fuse box?
  248. Tranny fill plug / oil change.
  249. CV axle removal.
  250. Fuel lines and fuel pump bracket
