Transfer case lift? Your ideas.
Hey guys I got my 7mge swap done in my toyota pickup. Im having a issue with the intake hitting the break booster. I did dent the booster about a 1/4 inch but dident want to beat it up to much. What do you guys think about building a spacer to lift the transfer case a inch or two so it will push the engine forward just a little bit to make the intake clear the booster? See when using the 5mge motor mounts ( engine side) it puts everthing at a 10 degree angle. Is there any affects of lifting the transfer case enought to gain some clearence?
I to noticed that 4crawler sales a transfer case lift. I had somthing like that in mind to build! I dont need much. Just wondering if it was a good or bad idea
Block of steel. It isent much drive lines dont bind at all. With the 5mge motor mounts it puts the drive train at a negitive angle of 10* so a little bit of lift on the transfer case is ideal when you got a 7mge engine swap!
FS[PacSouthWest]: FS: A340 transmission and t/case Lancaster Ca
4x4-runner
12-27-2016 01:58 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
yourrealdad
07-29-2015 11:08 AM
crashburnoveride
07-10-2015 06:39 AM
