How to drop oil pan on a '90 v6 4runner
Old 09-19-2010, 02:42 PM
Crimson Yota's Avatar
Unhappy How to drop oil pan on a '90 v6 4runner
Hey I need to drop the oil pan on my Automatic 1990 V6 4WD 4Runner.
I'm wondering how you do this?
I have the book but that only tells how to on a 2WD, and after searching for a good 15 minutes I could only find how to's on 2WD and 22RE models.
Any help would be greatly appreciated!
Thanks
Old 09-19-2010, 02:45 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Drop the diff...
I don't think it's as hard to do as ppl make out...
There's just 3 mounts for the diff...
You could just drop it, joints and all... Or remove the shaft, joints and diff completely from the truck...
To save time, remove the front drive shaft from the diff and wire it to the frame with a coat hanger, bungee or strap...
I.e, not the whole shaft, just half.
Old 09-19-2010, 02:51 PM
Does anyone on YotaTech see why Crimson can't just remove the CV axle bolts (that are behind the drive flanges or hubs), the front drive shaft at the diff, remove the two upper frame mounts, then with the front diff supported by a jack, remove the 4 bolts that hold the front x member and diff mount and lower the entire front diff and shafts out all at one time?
Old 09-19-2010, 02:53 PM
Alright thanks alot. Doesn't sound too hard.
Old 09-19-2010, 03:20 PM
92 TOY's Avatar
it's not that hard......
in "Thread B" in my sig, i have a whole section about doing this.
RDubya
02-10-2017 04:46 PM
83yotastockR
11
11-10-2015 06:54 AM
alexcarey
10-14-2015 06:05 PM
dzldust
7
10-06-2015 05:39 AM
viesail
09-21-2015 06:00 AM
Quick Reply: How to drop oil pan on a '90 v6 4runner
