starter contact replacement
Old Sep 15, 2010 | 07:47 AM
montana4runnin's Avatar
last night I took the plunge. Jumped in and replaced the starter contacts in my 95 runner. It took four hands (dad and I) but it was done in about 2.5 hours. After we were done, the knowledge would have led to about an hour total for removal, replacement, and remount, but its done and I want to thank all the folks for the knowledge and pics that made this easy. Thank you all very much.
Cole
Old Sep 15, 2010 | 01:09 PM
yotafool's Avatar
Have to do mine as well ASAP. Where did you get your contacts from? You guys recommend replacing the plunger as well?
Old Sep 15, 2010 | 02:53 PM
MudHippy's Avatar
No. But it doesn't hurt to dress the contact ring on it too. You know...like smooth it out with a mill file or some emery cloth. Or just hit it with a wire brush if it ain't too badly pitted. Try to keep the ring on the plunger the same thickness all the way around if you're going to remove any significant amount of material from it though.
Contacts are available from 4Crawler.com.
Old Sep 15, 2010 | 02:56 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
The easiest job you'll ever do on a Toyota
Old Sep 16, 2010 | 07:23 AM
i just took some emery cloth to the plunger. The plunger wasnt that bad and it was an extra 24 dollars from toyota so I opted not getting it. I also got my contacts from Toyota. a 10 inch extension is a must though. So the total cost of the change was just shy of 60 dollars. And another three hours of intamacy with the yota!
Old Sep 16, 2010 | 07:45 AM
MudHippy's Avatar
Emery cloth works good, I used a mill file last time. $60 is a little spendy, but not too bad compared to the price of a new one($120+). Refurbished units cost more than that too($65 and up), but I guess they may have more new parts applied. Anyway the experience gained is worth the price. Plus new tools are always a good thing(if you had to buy that extension?). Now you know how to remove, disassemble, repair, and install a starter.
I failed to mention(forgot)the technique that 4Crawler suggests on his site.
If yours is worn more, you might try chucking the end of the plunger up in an electric drill and spin it while holding some sandpaper to the contact ring to clean it up.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
thefishguy77
Jul 30, 2015 10:59 AM
ZONAYODA
Jul 13, 2015 07:17 PM
msane99
Jul 11, 2015 08:08 PM
colinmil
Jul 6, 2015 04:03 PM
