Best method 22re valve seals
Old Sep 12, 2010 | 10:34 AM
Flash319's Avatar
I am going to do the valve seals on my 22re and wonder what experience others have had doing these. I am going to try the rope trick but has anyone had luck with another way? comp air, rags....
Old Sep 12, 2010 | 11:06 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
delete
Old Sep 12, 2010 | 11:37 AM
RustBucket's Avatar
I used the rope trick on a 1.5L tercel engine once: OHC, side mount spark plug to very similar. It worked fine.
Old Sep 12, 2010 | 11:58 AM
Flash319's Avatar
Originally Posted by tried4x2signN
have the machine shop do it...
...That's the best method I know of
Maybe I can get them to change the oil to.........................
Old Sep 14, 2010 | 04:52 PM
thook's Avatar
Bring the vasoline. Walgreens is running special, btw.
Old Sep 14, 2010 | 04:53 PM
thook's Avatar
Oh, and a real answer......
I've never done the seals myself. So, no help here. Just more sarcasm.....
Old Sep 14, 2010 | 04:59 PM
delete...
Dang I miss-read this whole thing...
My goof, I thought you said guides not seals...
DEERRRRRRRRRRRRRRR!
Yes, run a shoe lace in the spark plug hole and run that piston up to TDC...
Then using a spring compressor remove the valve spring...
Dang, again, my bad...
Old Sep 14, 2010 | 06:28 PM
Flash319's Avatar
delete...
DEERRRRRRRRRRRRRRR!
I figured a bit to much green.....1300 posts and that was your bright idea.
Shoe lace eh, never heard of that. That might be easier to handle then the rope.
Old Sep 14, 2010 | 07:21 PM
yoterr's Avatar
i pulled my head and fubared one of the valves and had a machine shop reseat all the valves with new seals and one new valve for 120 bucks worth it to me that way all the valves seat properly buttt i had it off already too...yeah rope trick sounds worth it
Old Sep 14, 2010 | 07:29 PM
The compressed air thing scares me b/c it seems like the slightest movement or loss of seal on the valve and it would fall in.
The shoelace method is cheap, reliable and requires no special tools.
coleypull15
Nov 3, 2015 07:41 AM
Sep 4, 2015 09:27 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
cars-guy
Jul 11, 2015 07:51 PM
