overdrive relay clicking and overdrive not working
Old Sep 11, 2010 | 06:59 PM
urbanmisfit's Avatar
I have an 87 22r, recently the overdrive relay started clicking frantically. The problem comes and goes. While driving the overdrive seems to repond accordingly to the problem. It will only kick in some of the time, sometimes it will stay on for awile and sometimes it will just fire on and off in short bursts. Turning the windsheild wipers on will speed the clicking noise up. I have read in some other post that it is tied in from the wiper fuse. If i keep the OD button off the relay doesn't click at all, everything seems normal except the obvious fact that i have no overdrive. What might be the problem? Thanx in advance
Old Sep 11, 2010 | 11:21 PM
myyota's Avatar
You could have a shift solenoid going bad, you need to check for any codes that the transmission is throwing, that will give you an idea of whats wrong.
Old Sep 11, 2010 | 11:26 PM
myyota's Avatar
There is no need to ask the same question in two different forums, the mods don`t like that.
Old Sep 12, 2010 | 04:20 AM
Thanks for the input. Ya sorry about the double post. i'm new here, i only made the second one because i wasn't sure if i posted in the right area the first time.Tried deleting it and i can't figure that out either.
MO transplant
Apr 23, 2023 11:58 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
colinmil
Jul 6, 2015 04:03 PM
