Fuel Regulator ticking sound
Old Sep 15, 2010 | 10:10 PM
disfoolritehere2's Avatar
Thumbs down Fuel Regulator ticking sound
I have a 91 runner with the stock 3.0. I noticed that at idle, the fuel regulator is constantly ticking. Is this normal? I am having an issue with the truck idling hella rough almost to the point of dying out on me. Thanks for any help.
Old Sep 15, 2010 | 11:29 PM
thook's Avatar
It's normal, but check to see if there's any fuel in the vacuum line going to it.
Old Sep 16, 2010 | 10:49 PM
is there supposed to be fuel in the vacuum line? i didnt notice any when I pulled it off to replace it.
Old Sep 17, 2010 | 10:54 PM
thook's Avatar
No there isn't. So, good. It means the internal diaphragm is still good and the regulator hasn't failed. Atleast not in that way.
Try this; start the engine and let it warm up. Then, pinch the vacuum line to the regulator with some needle nose pliers and keep it pinched. Then pull it from the regulator. The idle RPM should jump up a bit. If not and there's no change, then you likely have a regulator problem.
Doug4320
Mar 24, 2018 10:11 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
cars-guy
Jul 11, 2015 07:51 PM
smiley52
Jul 11, 2015 05:16 AM
