PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 [146] 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. a/t reverse problem
  2. rust on 3rd gen (89-95)
  3. 1990 Pickup DLX to SR5 Frame up body swap (pics included)
  4. 1991 4Runner failed Texas Emissions - NOx - Saga
  5. Power steering
  6. Suggestions needed on where to start
  7. Wheel fitment, I've searched
  8. tires/odometer/mileage ; rule of thumb?
  9. New motor break-in
  10. Army vet scores at 4wheel parts, very nice!!!
  11. Speedy boot??
  12. parking/ e brake problemf
  13. Transfercase output shaft wobbles? New flange/Nut and still wobbles?
  14. Could it be the Head Gasket??
  15. 3vze valve timing help?
  16. LCE Clutch
  17. getting an 86 wont pass smog..
  18. 3vzetop end rebuild
  19. beep? is THAT what you call that strange sound?
  20. useless rear window wiper
  21. tire size vs odometer
  22. Parking Brake; To Use or Not to Use
  23. New Clutch + Massive Engine Oil Leak. Related?
  24. timing chain cover pan drop?
  25. The mechanic is stumped
  26. Overflow vacuum not working.
  27. No cold idle circuit?
  28. need 3vze mechanic Durango, CO asap
  29. first drive with the new header
  30. water leaking on drivers feet...HELP
  31. Got my Blower Motor Resistor, still need a little help!
  32. Flared bedsides help!!!
  33. Help with brakes
  34. Front Passenger Side Grind
  35. Replacement of "fake" water pump pulley
  36. Need a BIG favor in the Tacoma area. (a little welding)
  37. Long travel kit options
  38. Crane + MSD=??
  39. Idler screw?
  40. covering the rust
  41. Veteran's day's deals, from 4wheel parts!!
  42. Light Wiring - Combo switch doesn't completely disconnect ground
  43. sweet aftermarket 'runner tail lights!
  44. diy engine oil flush?
  45. 91 4 Runner Help
  46. 22re motor shaking
  47. how do i order them
  48. rusty tailgate replacement
  49. Front brake question
  50. CB Radio Installed
  51. need help with spare tire carrier........
  52. 87 pickup
  53. 22re ticking
  54. headlight issue! please help!
  55. Anyone Western Colorado? Need shop to play in!
  56. Prerunner bar!!!!
  57. Oil Pump? 3.0 motor 94 4runner
  58. Headers for swap?
  59. ball joint spacers for lift?
  60. Power Steering Conversion-93 truck 4cyl
  61. idle problem
  62. Yet again, Another Rear Window Thread...
  63. Relay
  64. heater core problem
  65. Pressing rear wheel bearings
  66. how important is the fan shroud? 3.0
  67. 3.0 to 3.4 swap
  68. Is there a common cause and resolution for DTC25
  69. Torque converter flex plate bolt up question?
  70. Brakes Broke
  71. new issue i came across
  72. im getting a code 12....
  73. distributor
  74. any makers on Carb manifold for the 3.slow
  75. hey guys can anyone give advice on a cheap paint job?
  76. 1994 toyota pickup locking hubs?
  77. 87 4Runner jumping out of 1st Gear
  78. Temp Gauge
  79. lil more mpgs please?
  80. Calling All 4Runner Owners!
  81. 3 CEL codes; 12,21,43!
  82. porting intake manifold 22re
  83. Whiney Pump? brakes and steering?
  84. go big or go home
  85. Blown 90 3vze Swapping A 92 In
  86. radiator questions for 22re
  87. Inspection/Exhaust woes and concerns
  88. New blinker set up for tube bumper
  89. Theories on Cause of Timing Chain Guide Breakage
  90. good deal??
  91. Tranny Swap???
  92. 1991 4Runner 4X4 SR5 V6 5SPD Project Pictures
  93. 1986 4runner 2.4L EFI stock (no electrical power)
  94. What to do on a recent purchased 91 4runner
  95. leaf spring Q on a 1986.
  96. MegaSquirt DIYPNP Your 22RE - The Tutorial!
  97. headlight question
  98. Emergency Brake Adjusment 88 Dually
  99. Broken
  100. '87 4runner 5spd shifter boot. Help Please
  101. Gas Gauge Issue
  102. 84 pickup rebuild Oil smells of gasoline!!!
  103. My 50 dollar paint job.
  104. Fuel pump for fuel cell
  105. IFS question
  106. Fuel Filter Location
  107. Does anyone *Actually Know* why we cant roll-start on dead battery?
  108. Rear window slider latch?
  109. bent suspension?
  110. My pulley is broke? What is it called?
  111. How to check for Power or resistance???Need help
  112. 3zve no compression on 6
  113. Rear Lockrite Broke...now what?
  114. ordered my header
  115. throttle body still black after using whole can of cleaner
  116. 1995 rear bumper
  117. Best MPG mods you've found
  118. a great mod i have discovered
  119. 92 3.0 fuel injectors leaking - rebuild help
  120. ABS block off?
  121. Installing Aussie in IFS, HELP!!
  122. another knock sensor wire. quick question
  123. Retightening Exhaust manifold bolts
  124. 3VZE knocking,give me some advice.
  125. Power Steering
  126. Anybody Narrowed a Landcruiser Front Axle?
  127. Dash lights on when brake applied
  128. vibration at low speed
  129. Valve sticking
  130. Downey Super Clutch. Now What?
  131. 5-Speed Manual Trans Leaking Fluid - Need Advice - Pics Included
  132. Exhaust stinks badly - I need education
  133. what is this bracket called?
  134. 2wd spindle & helper coil lift - pic heavy!
  135. LCE Test pipe
  136. 87 22R - Mixture Control Valve Tube ?
  137. anybody with the FSM?? help
  138. Fan noisy at highway speeds
  139. My 95 3VZE fails NOX portion of Cali. smog
  140. Stock 22RE Injector Characteristics?
  141. Aisin Hub question
  142. Cold Defogger
  143. Heater Problem
  144. 3.0 will not run under load
  145. Replacing driver's side window?
  146. Another code Knock sensor - 52... Has anyone ever replaced an ECU
  147. Other owners of a flex a lite black magic fan
  148. Heater
  149. Question on timing a 22R-E
  150. High gear, low rpm = bad engine shake..
  151. ifs lift
  152. 86 doors
  153. 89 yota project
  154. Catalytic converter relacement
  155. Score!!!
  156. HELP! 22RE hesitating/back firing
  157. HElp with this check engine light.. Blinks 3 times. need help thanks
  158. yes i was bored and get drunk while washing my 4runner and what!!!!!
  159. 4X4 Problem, not engaging
  160. Isr mod question.
  161. venturi source
  162. Coolant level confusion
  163. Brake Pedal is Hard, What Happens Next?
  164. my latest problem - starting/electrical...??
  165. Thermastat temp
  166. aussie locker
  167. What is measuremnt of freeze plug?!?
  168. v6 running very rough all of the sudden.
  169. 16 to 17 volts on battery post - alternator?
  170. toyota help.....
  171. 91 toyota pick up leans to passenger side
  172. 4WD Shifting Problem
  173. Jipo Work
  174. Idle adjusting screw vs. Idle mixture
  175. Need Pics of vacuum hoses
  176. Alternator rebuild or buy from Autozone
  177. Fuel too Rich? Failed CO smog test.
  178. Problem starting? Distributor 180 out of place?
  179. eletrical short
  180. Valve Adjustment/Knock question
  181. Need help finding idle issue
  182. 94 4runner 3VZ-E vacuum problem!
  183. Smooth idle... but...
  184. check engine light
  185. Camper top fit
  186. 7mgte enigne
  187. 2 questions, 88 4runner
  188. Studded rubber on your trucks
  189. 88 runner Power Steering Woes
  190. no Low beam in one headlight
  191. 2010 4runner
  192. Knock after rebuild
  193. RED HOT Exhaust pipe!
  194. Best surpentine belt and water pump?
  195. 4x4 engaging by itself?
  196. When in low range if I shift to second the shifters rub
  197. tapping noise in 3.0L V6 1990 4Runner
  198. CARB Legal 22re Power Mods (Search hates me?)
  199. Oil leakage
  200. Questions on Adjusting valves!
  201. Can I use anything off this?
  202. Switching to synthetic
  203. MY new 1995 4runner
  204. 3.0 running issues
  205. clutch pedal bracket broke need help asap!!
  206. Ignition Cylinder stuck
  207. grill and bumper question
  208. Does this not look right on my 3VZE
  209. Fixed my saggy 4Runner ass on a budget
  210. 91 4runner timing problem!!
  211. 3.0 Question
  212. OIl Pressure Gauge?
  213. New T.G. Bumper Installed
  214. Rear window post #3,128
  215. whats supposed to be there? (pics)
  216. baja rack mounted on 90 pickup
  217. Flex-a-lite fan???
  218. Has anyone used alltoyotatrucksuvparts.com
  219. EGR valve removal for performance?
  220. Front Crank seal DIY?
  221. what is it?
  222. Proper Head Installation
  223. Need your thoughts on tires
  224. bodypart/bumper question...
  225. Mechanical Speedo Correction Box - Install with Pics
  226. Steering idle,.. HELP
  227. tailgate wiring
  228. Spun Bearings
  229. Tailgate handles, Ebay?? Anyone have one for sale?
  230. '87 4runner sputtering. Help please.
  231. Exhaust manifold question
  232. 95 4Runner Project
  233. Favorite exhaust shop in Tacoma, Wa
  234. Should i swap my grill for a 4runner grill?
  235. Isr problems plz help
  236. Couple things
  237. Auto shifter bushings?
  238. Water leak at rear of the engine
  239. High Output Alternator Help.....3.0 ????
  240. 90 V6 4runner low idle, low oil pressure..
  241. Lots Of Smoke And Gas Smell
  242. trailer hitch
  243. Chromoly Axle Shafts for '91 4Runner
  244. SAS on 88 4runner
  245. Block heater for a kzn-130
  246. code 11 question
  247. Oil Leak
  248. please help
  249. Need quick advice
  250. front diff problem
