no Low beam in one headlight
Old Nov 6, 2009 | 12:27 AM
saskyrunner88's Avatar
okay i have an 88 4runner and the right headlight wont turn on low beams but high beams work. i tested the wires at the three prong outlet that plugs into the headlight and it has power to the two of the wires same as the other left side. any ideas? is it just the bulb?
Old Nov 6, 2009 | 12:34 AM
Elton's Avatar
low beam is burned out replace it or get a h4 conversion see my thread
Old Nov 6, 2009 | 12:35 AM
seanmearse's Avatar
Replace the bulb and it should be fine. I work auto parts, have for three years, its very very common the low beam goes out.
Old Nov 6, 2009 | 12:36 AM
wow you yota tech guys are sure quick to respond haha awesome. thanks for the help. how much would you say the h4 conversion is?
Old Nov 6, 2009 | 12:37 AM
seanmearse's Avatar
Beat me to it.
Old Nov 6, 2009 | 12:45 AM
Elton's Avatar
o yea the bulb isn't replaceable cause its a sealed unit heres a link to the h4 conversion
https://www.yotatech.com/forums/f116...talled-159609/
Old Nov 6, 2009 | 01:45 AM
Matt16's Avatar
You've got daytime running lights (DTRLs), you've burned out your headlight that's all. The highbeam is a different filament and will still work if its just the bulb.
Old Nov 6, 2009 | 04:49 AM
vermontoyota's Avatar
I just got new sealed-bulb units at Bond's for $14 each and those were the brighter ones. Much brighter, very easy install, and cheap!!
Mine were not burnt but so bad I left High beams on always and NEVER got flashed and it was still misserably dim. Make the swap.
Old Nov 6, 2009 | 08:21 AM
seanmearse's Avatar
I new that, im an 84. But, bulb light, eh, its all the same, lol.
1uzRunner
63
Nov 10, 2018 03:58 PM
justdifferentials
Just Differentials
Sep 8, 2015 03:15 PM
justdifferentials
Sep 8, 2015 03:13 PM
moparbay
Sep 3, 2015 12:48 PM
RobotMoose
Sep 2, 2015 05:53 AM
