When in low range if I shift to second the shifters rub
Old Nov 5, 2009 | 08:05 PM
dhall50's Avatar
Question When in low range if I shift to second the shifters rub
86 22r with 3inch body lift. When I am in low range and I go to shift into second it will hit the tcase shifter and knock it out of low range. We extended the tranny shifter and they still hit. What solutions have been used to remedy this situation?
Old Nov 5, 2009 | 09:41 PM
peow130's Avatar
transmission shifter on backwards perhaps?
or, you can take it out and bend it.
Old Nov 5, 2009 | 09:46 PM
camo31_10.50's Avatar
WORN OUT SHIFTER BUSHING!!!
lol
and i've been told that it's bad to be in ANY gear except 1st and reverse while in 4lo...
but my friends and I regularly wheel in 4lo and 2nd gear...sometime even 3rd or 4th..it turns our M/t's a LOT better than 4hi..lol
Old Nov 5, 2009 | 10:15 PM
peow130's Avatar
same, i stay in 2nd when in 4lo, too.
1st is just too slow, especially when trying to climb sandy hills.
and 4high 1st is too little torque
Old Nov 5, 2009 | 10:19 PM
gary96360's Avatar
hha i never use 4 hi in the bush. only use 4 low 2nd to start off
Old Nov 5, 2009 | 10:24 PM
dropzone's Avatar
Fossilized
all the theories of when to use 4 low or 4 hi don't solve the shifter hitting the tc level,
dog leg your TC shifter, either by cutting and welding (what I did) or heat and bend.
remove the shifter first, do not attempt to tweak it while in the truck or you will be up poop creek
Old Nov 5, 2009 | 10:26 PM
nahh..he'll just torch the cab..lmao..then it'll blow the fuel tank because the gasoline inside the lines will reach it's flash point..lmfao
Old Nov 5, 2009 | 10:49 PM
peow130's Avatar
see 2nd post, lol.
oh and, who said it was bad to use 2nd gear and 4lo?
Old Nov 6, 2009 | 02:58 AM
dropzone's Avatar
Fossilized
i misread it...
Old Nov 6, 2009 | 10:20 AM
gary96360's Avatar
when i did my 3 inch body lift i didnt bother to extend the shifters all i did was bend it forward and to the left a bit then turned the shifter plate 180 degrees and grinded it so i can use 4 low
Old Nov 6, 2009 | 10:21 AM
peow130's Avatar
i misread it...
its no biggy.
Old Nov 6, 2009 | 11:32 AM
deathrunner's Avatar
I use all my gears in 4lo. That's bullsnizzle. Why else would people brag about having 24 speeds with dual cases?
Old Nov 6, 2009 | 12:09 PM
Jay351's Avatar
I had to heat and bend my shifter to clear the t-case shifter.
Easy stuff, that and flipping the inner shifter boot gave me clearance for everything.
Old Nov 6, 2009 | 01:28 PM
interested2meet's Avatar
wrong trans shifter
my truck did the same thing, apparently at some point someone swapped trans and used the stick from whatever trans they had gotten and wouldnt clear t/c shifter in second. i found the correct shifter for the trans which had a factory bend in it to fit past the t/c shifter. may check may not be the right trans shifter for ur ride.
Old Nov 6, 2009 | 01:35 PM
904_runner's Avatar
I use all gears in mine..
Oh the day i will have duals..
Old Nov 6, 2009 | 02:28 PM
peow130's Avatar
yeah i max 25mph in 4lo
Old Nov 6, 2009 | 02:36 PM
lmao..thought i was right ..hahahaha
now i will continue to use 4lo while wheeling..unless im runnin some dunes..then it's 2wd lol
Old Nov 6, 2009 | 02:39 PM
peow130's Avatar
i'd still keep it in 4wd for dunes, lol.
Old Nov 6, 2009 | 02:40 PM
LOL..i will most of the time..but with my CV's bein as bad as they are..i dont wanna go fast in 4wd hahahaha
don't wanna have a CV blow up on me out in the middle of nowhere
Liadrin
Apr 25, 2022 02:54 PM
RatOmeter
Oct 22, 2015 03:17 PM
Liadrin
Sep 1, 2015 06:44 AM
crashburnoveride
Jul 10, 2015 06:39 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
