Oil Leak
Old Nov 4, 2009 | 06:06 AM
buckshot1224's Avatar
Oil Leak
I'll introduce myself with a question that is kicking my butt so far. Just bought this truck last week for $1800. 1991, 145K miles, V6, 4wd, great shape........problem is the guy hasn't driven it much at all in the past 2 years and I've got something that I've got to get right.
Can't exactly pinpoint where this is coming from so I need some ideas. Motor runs great but I've got an oil leak come from the front of the motor and it seems to be more towards the driverside. I didn't think the whole deal was the valve cover gaskets but I replaced them anyways on both sides..........well it doesn't seem to have slowed it up any. It is coming down the driver side getting on the alternator bracket and all over everything below that. I'm thinking it could be behind the timing belt cover but I'm not familiar with that area........... Any ideas on what this could be? Common issues? What parts may I need?
It has to run for a while for the oil to start showing and dripping.........well almost pouring..........
Thanks!!
Old Nov 4, 2009 | 06:08 AM
92 TOY's Avatar
i may be wrong, but check the distributor area. i think there is a seal (o-ring?) there.
Old Nov 4, 2009 | 06:09 AM
Ardent's Avatar
Cam seal or maybe a loose oil filter. Cam seals are cheap. The labor sucks.
Edit- distributor is a good idea too. ^^
Old Nov 4, 2009 | 06:13 AM
92 TOY's Avatar
chime in about this.......
I saw a post (somewhere) about putting talcum powder down to see where the leak originates from because it will leave a trail.
Old Nov 4, 2009 | 06:24 AM
snobdds's Avatar
Front Crankshaft oil seal, Oil pump gsket, timing cover gasket, distributor. If not those, you could be leaking where the head gasket meets the top of the timing cover.
Old Nov 4, 2009 | 10:07 AM
o boy...........well got some places to investigate at least
Old Nov 4, 2009 | 10:41 AM
lordhowe's Avatar
i've got some similar. driver side coming down from the tranny (but tranny is not leaking).
mine drips a little, like a quart every few thousand miles so i'm not too worried. oil is cheap
Old Nov 4, 2009 | 10:45 AM
well mine lost 3/4 of a quart or so of motor oil in 65 miles..........not going to work........
Old Nov 5, 2009 | 06:39 PM
Spent about 2 hours trying to find the leak Wednesday night..........finally got in the truck and got it up to about 3/4 throttle and held it there......5 seconds later it started pouring out of the front camshaft seal..........fixed it today in about 3.5 hours......so far no leaks.
Old Nov 6, 2009 | 01:42 AM
92 TOY's Avatar
good job
Old Nov 6, 2009 | 05:42 AM
Wes94's Avatar
Nice work. Did you take any pictures of the process?
Eggslinger
Jun 8, 2019 03:32 PM
Ladythump
22
Nov 9, 2015 08:53 AM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
