Spun Bearings
Old Nov 4, 2009 | 06:51 PM
iCavity's Avatar
Spun Bearings
I was wondering what the symptoms are of spun bearings on the bottom end of a '94 22r-e?
And what could cause them!
thanks!
Old Nov 4, 2009 | 07:01 PM
dntsdad's Avatar
something like the sound of a monkey with a hammer in your block beating on it.
Old Nov 4, 2009 | 07:07 PM
98srx6's Avatar
If you spun a bearing (rod or main), you would definitely know it. Extreme metal-on-metal knock.
Oil starvation is probably the most common cause of this happening.
Old Nov 4, 2009 | 07:21 PM
iCavity's Avatar
Oh ok! thanks!
Old Nov 4, 2009 | 08:05 PM
modlite's Avatar
the bearings are also pressed in between the connecting rod and the cap. This keeps it in place.
If you have a spun bearing it will most likely seize the motor.
Old Nov 4, 2009 | 08:14 PM
TOYOTA 1's Avatar
^ uhh no.. it sill still run fine, just sound horrible.
Old Nov 4, 2009 | 08:15 PM
turboboost's Avatar
Lies, it might run for a bit, but it will seize up after time.
Old Nov 4, 2009 | 08:28 PM
TOYOTA 1's Avatar
well every thing will go bad in time.
mine ran for 2 weeks with a spun bearing. rolled new ones in, and then drove it for another 2yrs. then blew a hg, built a new motor with the same crank, "machine shop said it was in great shape". 25k on new motor with the same old crank, still runs great. even after a hydro lock.
besides he made it sound like, (or i assumed) it would instantly seize after a spun bearing.
no lies, i only stated my experience.
Old Nov 4, 2009 | 08:32 PM
camo31_10.50's Avatar
LOL..too bad the '92 4runneri just bought has destroyed the bearings..LOL..now i gotta rip that 3vz out..rebuild it..drive it for a while..then rip it out again..and put the 3.4 in it
i've heard A LOT of old chevies and fords runnin around that sound like they have about 5 monkeys each with 2 hammers bangin on the inside of the motor....and they drive em for years..but are VERY VERY VERY easy on em..LOL
Old Nov 5, 2009 | 05:54 AM
modlite's Avatar
Why do you think the bearing spun in the first place? Because the crank or rod seized on it, grabbed it and spun it around. It's gonna seize again
Old Nov 5, 2009 | 06:38 PM
dntsdad's Avatar
Mine spun a bearing and I replaced that bearing and all the others with new standard sized ones. That was over the summer and its still going. Knock a bit but not that bad.
Before I replace the bearing it sounded really loud. Like the monkey and hammer I mentioned. I had a thread here
ladybugRC
458
Aug 21, 2020 10:41 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
Odin
Sep 26, 2015 06:56 PM
