Installing Aussie in IFS, HELP!!
Old Nov 8, 2009 | 07:26 PM
r2m's Avatar
r2m
I did an Aussie lunchbox install in the rear 8" on my 89 PU yesterday, not bad. First time I've ever been in a dif.
Now I'm installing the front.
I have the left front rotor off, drive shaft off and drained the oil.
BUT: How does one move the axles out to remove the 3rd???
Am I doing it right? Or is there another way to be able to slide the axles out a couple of inches?
I have looked/googled/yota'ed everywhere for info for how to install an Aussie locker in a Toy IFS and there's just nothing out there.
And I really need to get this going, it's my daily driver.
Help me. I've fallen and I can't get up......
Also, where can I get one of them 54mm sockets for the front axle? I had to use....
nevermind, and the nuts arn't damaged, but the right tool would have helped!
Thanks in advance for any and all assistance!!!
Old Nov 8, 2009 | 07:34 PM
peow130's Avatar
You don't need to do all that..
Unbolt the CV's from the front diff, and unbolt the 3 bolts on the differential to drop it.
Don't forget the 4 bolts for the front driveline.
To remove the CV's from the hubs, you'll need to remove the hub face, and a gold bolt on the inside of the hub...
You don't have to take off the rotor lol.
Old Nov 8, 2009 | 07:39 PM
88Cleve4runner's Avatar
yeah if all you're doing is taking your front third out to lock it, you have 4 bolts to take off the dshaft, 12 total bolts for the cv's, 1 bolt in front of the diff, 2 bolts above diff. you don't have to take your cv's off to take your front diff out. then take off the front cover and you're in.
while its out, go ahead and take out your studs that hold your cv's in and replace them with nuts and bolts. super easier way to change a cv off road.
Old Nov 8, 2009 | 07:45 PM
drew303's Avatar
What they all said. Maybe when you have everything out, bust out the torch and snarf all the IFS Crapola out from there and weld in a hangar, some frame jigs, hang some springs and a 85 trussed axle under there
Old Nov 8, 2009 | 07:54 PM
peow130's Avatar
it's easier to put the front diff back in without the CV's in.. then you can slip the CV's in after it's all done..
Old Nov 8, 2009 | 08:06 PM
89silverpu's Avatar
He's not saying put the front diff back in with the cv's attached, hes saying knock out the studs (or grind the splines down) so they slide in and out so you only have to take the hub assembly apart to get the CV out if you break it wheelin. After doing this, it will slide down through the LCA.
Old Nov 8, 2009 | 08:08 PM
89silverpu's Avatar
Oh, and this should help:
http://gearinstalls.com/ifs.htm
Old Nov 8, 2009 | 08:28 PM
peow130's Avatar
"you don't have to take your cv's off to take your front diff out."
With the CV's in it's a pita to get it lined up correctly..
But if you take the studs out then it's np.
Old Nov 8, 2009 | 08:47 PM
Stuwy123's Avatar
Don't grind the splines off the CV bolts!!! The splines spot the bolts from loosening off.
Remember to use a nut on the bolts when you pound them out of the CV's.
Old Nov 8, 2009 | 08:54 PM
peow130's Avatar
if you're taking the studs out, and replacing them with new grade 8 bolts, then it doesn't really matter if you grind them down, lol.
Old Nov 8, 2009 | 08:59 PM
89silverpu's Avatar
I ground mine down and have had zero problems with them loosening.
Old Nov 8, 2009 | 09:05 PM
TOYOTA 1's Avatar
why even take the studs out?
its easy to swap a 3rd out, and it only takes like 30 minutes. i guess it would make it easier though
flyingbrass's Avatar
Wabfab sells the 54mm sockets (3/8" drive). So does Marlincrawler.com (1/2" drive).
Old Nov 8, 2009 | 10:09 PM
peow130's Avatar
because when you go to put a CV back in, it's a serious pita to maneuver it through those studs, lol..
Old Nov 9, 2009 | 07:10 AM
r2m's Avatar
r2m
Been to Zuk's site and there is nothing relating to what is necessary to to get to the point so one can slip out the 3rd.
Albeit, this site was handy for the rear install! Didn't need any grease for holding the pins and springs in, just for the face-to-face.
Thanks for the input!
OOPS!!!!!!!
My bad, I should have gone to the link "gearinstalls.com" that you had posted. It DOES have a thorough removal of the front dif.
I humbly apologize 89silverpu....
icentropy
Sep 16, 2020 02:47 PM
delmert
Sep 30, 2015 04:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
scottyg486
Jul 19, 2015 05:34 PM
skoti89
Jul 6, 2015 07:45 PM
