- Ignition switch swap & High Altitude Compensator replacement
- Replace head gasket now not getting spark from coil
- '93 Xtra Cab Resto Project in Wisconsin
- Sweet V6 '88 4runner for someone
- Using ATF as P/S fluid?
- Need help finding an a/c line
- Coolant in Intake Manifold
- More - My 87 Toyota 4X4 or Fun and mysteries of restoring a Toyota 4X4 that is a "gem
- How to replace sliding window seal on 88 4Runner removable top?
- 4Runner RC model
- Help finding correct parking brake cable 90 3.0 sr5 4x4
- Gas tank pressure
- 22re Upper Radiator Hose Diameter?
- 95 toyota pickup
- I have a 1992 toyota pickup extended cab, she has a really hard time starting up
- 3.0 rebuild- runs- won't rev up- dies
- shock length.
- high fuel consumption
- 1986 22re bubbles coming from radiator.
- Ac pressure spiking, engine getting hot at idle
- Vapor lock
- Anti Lock Light
- Neutral/clutch safety switch temporary bypass?
- Top end knock
- 88' 4 runner issue
- 4runner wont move after over heating
- Question about throttle swap
- Exhaust manifold to downpipe connection.
- 22R (carborated) ground connections
- transfer case front output seal
- clutch adjustment
- Not starting
- smelly exhaust sometimes
- rear O2 sensor
- loose steering box
- window crank handle
- temp gauge fluctuating problem
- 22r main seal retainer while on engine stand?
- 1986 4runner 22re no power after rebuild
- Leaking fuel pressure pulsation damper
- Might need a new head.
- Brake sinking to floor
- Mystery part
- Front cross member hardware
- Mystery no-start - ideas?
- Cannot get Check engine light to come on!
- Front End Noise
- My First Yota
- 94 4runner brush guard
- Looking for an OEM shock recommendation
- 87 4Runner E-locker?
- upper control arm bushing
- Torque spec. Question?
- What Is This Part?!?!?!?
- Drum brake backing plate bolt spec
- Vapor canister, 93 3VZE 6 cylinder
- 1994 T100 Turns over but won't start sometimes
- 1995 4 runner Overheating
- '94 Pickup braking system issues
- Body Work: Seam Sealing Gutter
- Bottom end 22re rebuild question
- 86 22r afterfiring
- Where does this go
- Truck's first timing chain change, should I resurface the head too?
- No Power to fuse box. Inside the truck
- Can't Find A/C Parts
- 86 4Runner RTE won't start after adjusting distributor
- Failed smog due to timing
- backspacing for 15x8 wheels
- Max-Bilt Center Console
- What does a healthy 22re sound like?
- FJ62 speedometer
- street suspension
- 1991 3.0 hissing coolant leak overheating bad
- 22re fuel injector electrical connector
- Bad Valve?
- 92 drivers side door
- Checking Idle, Timing Advance - 22RE
- Bed Panels
- A/C Amplifier Pin #7
- Help!!!!!!
- Wanting to Re-Do Door Panels Custom
- '86 22RE... Busted timing chain. What to do about valves?
- Power Side Views
- 2005 into a 90 Suspention and other parts
- what is this trim piece called on a 4runner?
- Identifying 4x4 transmission
- Baffle plate, do I need it?
- 1988 Toyota pickup won't stay idiling
- Drive Shaft Turning In Neutral -One Wheel Off the Ground
- W56 B Trans Rebuild detailed w/ pics
- 16.5" fender to rim torsion measurement?
- Nylon Shifter Bushing
- Would these pistons change performance over stock?
- WTB: 86-95 Toyota Pickup or 4Runner
- Toyota camper shell question
- Faulty TPS and gas in oil
- 1990 22re 2wd brake pad ?
- Clicking or tapping noise on deceleration with foot slightly off the gas
- Need help identifying fuel lines
- Fixing highway shaking
- 93 pickup build
- 1995 Power Window only goes down
- Snapped off hose connector
- 22re now with terrible mileage
- No interior light when opening driver's door
- Best rear diff for 31s for highway?
- Pickup overheated
- Puckup over heated
- 22re -- Loss of power / fluttering sound when accelerating uphill
- 1986 22re 4runner plug identification
- Gen1 4Runner Front Diff swap/re-gear
- LLoyd Mats Rubbertite - 1989 Gen1 4Runner
- what is the easiest way to remove oil pan from 95 4x4 4runner 3.0
- 1991 pickup 22re bogging at high speeds
- Ls1
- Cost to Have Fuel Line Replaced
- 87 22RE Blowing Engine Fuse
- A/c only works with high idle
- Help with bracket
- Reverse lights on in all gears except reverse
- PSA: Alternator overcharging battery
- cruise control
- Warm A/C no cold air, only blows cold sometimes
- 91 22re overheating
- 88 dead after ign switch replaced HELP
- 87 4Runner auto to manual help
- finally finished rebuild on head gaskets
- Late model FPR vacuum routing
- 3vze Timing help
- 88' 4runner timing chain
- the famous 3.4 swap
- 1991 pickup parts incompatable
- Steering and Linkages IFS with Torsion Bars 1986-1995
- Bumper Ends
- 1999 toyto tacoma
- A little help with my 86
- Intake removal 92 Toyota pickup 4cyl
- 89 pickup, gas gauge stays on E, what to check? buy?
- Replacing Ball-Joint on IFS with Torsion Bar 1986 to 1995
- Help with 87 or 88 4runner FSM
- how hard is it to go back to a 22re from a 22rte
- 134a conversion Toyota part #'s
- Master Cylinder interchangeability.
- A/C quits at highway speeds only.
- Stock Ride Height?
- Needed to Smog messed up timing
- Rough country lift
- Parking brake fails to operate even with proper adjustment
- A/C added to '92 pickup
- 3.0 injector issues
- Value of my truck?
- Doing cv axles, what else?
- 94 4runner....need help/ advice
- Rapid blinking CEL
- OEM Vinyl Floor?
- Trouble codes and stalling in gear
- pwer loss reset
- 93 v6 oil leak issues
- CV Axle Recommendations?
- 93 v6. Head bolts
- one piece bumper
- 3VZE Throttle Body Swap
- Wheel swap
- torsion bar help!
- Replacement vacuum hose
- 22re Removing Cam Bolt
- What do i do now?
- clutch pedal bracket different from replacement? 1990 4x4 v6
- Tachometer problem
- turn signal not working!!
- Rear cam seal question
- 22re Rebuild 88 4Runner
- 1986 Xtracab Rear bench
- Ugh! Stock looking radio with bluetooth?
- 1992 Toyota ext.-cab pickup 3.0 v6 won't Crank at all
- 89 Toyota p[ick up 22R carb suddenly wont idle
- 1987 4runner automatic code 42 and 61
- Ac fuse location 93 4runner
- Front differential leak
- 3800 rpm at 65 mph
- Looking for ideas
- Trouble codes 42 and 43
- Question about Smog Pump
- Lifting question 95 3rd gen truck
- 92' Toyota ECU replacement.
- Replacing Seat Belts
- What is this???
- Smoke at startup
- v6 Brake Upgrade Questions
- 3VZE dies when hot
- Rear Brake Shoes for 1986 4Runner PN 04495-35110 or 04495-35112
- Original A/C in need of charge
- erratic idle (89 sr5)
- 95 pickup 3.0l dashlights and tail lights out.
- Pic Request: Dead Pedal Bracket behind carpet(and dead pedal)
- Misfire? HELP!!!
- Yay - New Key!
- gas cap
- five speed rebuild
- got it running
- CEL intermittent on, no codes
- How to Inspect Water and Oil Pump
- rebuild or buy new
- neighbors truck
- fickle fuel system
- Rear end rotational play
- side window deflector
- Water leak
- 02 sensor wiring pic
- Breaks
- 91 4x4 22re 5spd brake and battery light on
- Completed rebuild of 3vze, need some advice
- 91 toyota pickup battery installed backwards need some advice
- '92 4Runner rough idle and need a part number
- 22re engine complete gasket set kit issues
- Steering box - input side
- 1990 Toyota Pickup Manual Transmission Accelerator Sticks
- 1988 Toyota Pickup Factory Service Manual (fsm)
- Idle Speed Screw O-Ring Part Number Inside
- Starter Rebuild
- 93 A/C problem
- '88 3VZE Pickup Fan Belt Replacement
- 1987 Toyota pickup A/C Installation
- Swap info
- Timing and no horsepower
- 93 Pickup replacing A/C problems
- Cheapest and easiest way to lift any pickup?
- Timing belt/water belt/serpentine replacement, 1991 toyota p/u 3vz-e
- 87 pickup budget build
- fuel line diagram
- used to be
- i pulled the handle off the ebrake, how do i fix?
- 1993 toyotat pick up 22RE engine
- 88 22R trying to track down a tick
- 95 4runner a340h tranny question
- 93 4runner 5spd issues
- 3VZE Low Idle, driveabilityissues HELP!!
- Guy who was looking for harness plugs??
- Tachometer tester advice
- 92 4Runner Won't Start After Arcing Wires
- No power, no fuel to driver side injectors??
- Fuel Pump Issues
- 94 4Runner steering rebuild
- 86 22r Need some help identifying parts and missing vac hoses
- 91 4runner 3.0
- Door Lights
- transmission input shaft seal replacement
- 1993 V6 4x4 4runner with A340H Auto Trans will not shift past 2nd Gear
