Top end knock
Old Aug 29, 2017 | 06:24 AM
tesflaux's Avatar
Top end knock
I have an 87 22r pickup 2wd. The other day when I got on the gas it started knocking at a higher rpm so a friends suggested adjusting the valves so we did. After that it's been a constant knock with a lack of power. The knock kinda makes it sound like a Diesel engine. Any ideas?
Old Aug 29, 2017 | 06:30 AM
L5wolvesf's Avatar
What specs did you use when you adjusted the valves?
Old Aug 29, 2017 | 06:48 AM
dropzone's Avatar
Fossilized
i was half awake once adjusting valves and used thousands of an inch instead of metric thousands..
Old Aug 29, 2017 | 07:06 AM
tesflaux's Avatar
.008 on the intake and .012 on the exhaust
Old Sep 1, 2017 | 05:24 PM
andrewp24's Avatar
Compression test?
It could be a rod knock. Does it sound like its detonating from the timing being off / bad gas or a metal on metal knock?
Old Sep 5, 2017 | 04:22 PM
John B's Avatar
i have a 1986 22r and my motor knocks as well . i am also trying to figure out what it is i checked compression and i have 150 in all 4 cylinders witch is not bad . also adjusted the timing it was off by 5 degrees . also did the valves and it continues to knock . any ideas???
