1991 pickup parts incompatable
Old Jul 29, 2017 | 05:32 PM
yngbuck19's Avatar
Not sure how normal this is but I am running in to this for the first time with my new truck. I have a 02/91 Toyota pickup 2.4 22re 4x4 auto FYI. I ordered new parts for the A/C system and none of them fit. When I ordered them I used 1991 Toyota pickup as a filter so maybe I was wrong to assume they would be the right parts.
To fix this I used 1988 Toyota pickup as a filter and all the parts matched up.
Should there be anything else I should look out for to be this way when replacing parts on the truck?
Have you run into this problem yourself?
Let me know.
Thanks, Robby
Old Jul 29, 2017 | 05:52 PM
old87yota's Avatar
Hummmm.... That is strange.
Do you know if this truck had A/C from the factory?
1884-1988 Trucks had their own system and 1989-1993ish had a very similar system, but the parts were slightly different in size.
Maybe someone added A/C from a 1984-1988 truck or the dealer added A/C from an old "dealer installation" kit for 1984-1988. If you had all the parts to the older style HVAC system, you could install it in the newer trucks and make it work.
Old Jul 29, 2017 | 06:01 PM
yngbuck19's Avatar
It is a deluxe model as far as I can tell from the VIN#. So yes it would have been on there from the factory I assume. Yeah I'm finding out really fast that the previous owner(s) have not taken very good care of this truck. There's been sparkplugs cross threaded, bolt missing from the A/C compressor, shady wiring under the dash, A/C compressor hot wired to the Battery and a toggle switch, back sliding glass pried into. All kinds of shenanigans. Who knows what else I'll find.
Old Jul 29, 2017 | 06:21 PM
old87yota's Avatar
Originally Posted by yngbuck19
It is a deluxe model as far as I can tell from the VIN#. So yes it would have been on there from the factory I assume. Yeah I'm finding out really fast that the previous owner(s) have not taken very good care of this truck. There's been spark plugs cross threaded, bolt missing from the A/C compressor, shady wiring under the dash, A/C compressor hot wired to the Battery and a toggle switch, back sliding glass pried into. All kinds of shenanigans. Who knows what else I'll find.
Back in those days a deluxe was basically a "base model". A/C was an option that could be added but it did not come standard.
Given your description of the truck's condition, who knows what was added or pieced together.
I hope you don't find too many more surprises!
Old Jul 30, 2017 | 01:12 AM
wyoming9's Avatar
Red face
It is a older Toyota one may find anything done to keep it running .
I remember running into two different Compressors during those years.
Just what AC parts were different ??
Old Jul 30, 2017 | 01:33 AM
yngbuck19's Avatar
A/C Reciever/Dryer and the A/C compressor so far that's it, both are older models from the 1988 trucks. They could be either aftermarket or found in a junkyard and swapped on to the truck for all I know.
