91 4runner 3.0
Old Jul 5, 2017 | 04:01 PM
Armyross27's Avatar
91 4runner 3.0
Need help! 91 4 runner starts sputtering after hot i can start it drive it and its fine shut it off let it sit for a bit start it back up and its sputtering, it has new fuel filter plugs wires cap and rotor 6 month old fuel pump new 02 senseor cleaned cold start injector timing belt 2 months ago please help
Old Jul 5, 2017 | 04:49 PM
thook's Avatar
some punctuation would be nice!
is it "starts sputtering after hot"?
or, is it "after hot, i can start it, drive it...."?
Old Jul 5, 2017 | 04:57 PM
Armyross27's Avatar
After its hot from driving it when i start it back up its sputtering
Old Jul 5, 2017 | 06:39 PM
thook's Avatar
that's a common problem for a bad fuel pressure regulator under "heat soak" conditions.
start it up, let it run a minute or two, then see if there's fuel in the vacuum line going to the regulator
Old Jul 8, 2017 | 04:49 PM
Armyross27's Avatar
i checked the regulator there was a small amount of fuel in the vacuum line, i changed the regulator and the cold start injector and its still doing it
Old Jul 9, 2017 | 08:33 AM
Jacobfarms's Avatar
Need a fix asap please! I'm trying to pull haul stuff and my o/d off does not work at all. The button on the shifter clicks like it's suppose to but I get no light and when I'm driving and o/d is in the off position it still goes into o/d any ideas about what I should be checking????
Old Jul 10, 2017 | 10:05 AM
thook's Avatar
what's the age/mileage on the engine? have you ever had the injectors reconditioned? could be one or more leaky injectors.
Old Jul 10, 2017 | 10:07 AM
thook's Avatar
maybe the connector under the console cover
Old Jul 10, 2017 | 01:02 PM
Armyross27's Avatar
245,000 miles. I've had the truck for 5 yrs put 100,000 on it and never had them reconditioned. I was wondering if maybe they were leaking too so i pulled the intake off and checked them all they dont seem to be leaking. I also did a drop test on all the cylinders and when i pulled the #2 there was no change but i do have spark to all 6. But again it runs fine when i first start it up. But once its warmed up it sputters and runs rough.
Old Jul 10, 2017 | 01:28 PM
Jacobfarms's Avatar
I'm trying to haul stuff and my o/d off does not work at all. The button on the shifter clicks like it's suppose to but I get no light and when I'm driving and o/d is in the off position it still goes into o/d any ideas about what I should be checking????
Old Jul 10, 2017 | 03:32 PM
thook's Avatar
well, it wouldn't hurt to have them reconditioned at that age
then, maybe test your coolant temp sensor. not the sending unit for you dash gauge. the one for ecu fuel trim/timing
Old Jul 10, 2017 | 03:34 PM
thook's Avatar
did you not see i gave a possible answer? try the connector see if it's dirty. or, maybe the switch itself in the selector handle
Old Jul 10, 2017 | 07:28 PM
Armyross27's Avatar
I replaced the temp sensor last year, im going to replace the injectors this weekend and see how it goes if that dont work i might just have to do an engine swap, This truck ran perfect up till this last year and im getting irritated with it thanks for the advice
Old Jul 10, 2017 | 10:29 PM
Jacobfarms's Avatar
the handle doesn't seem to want to come off. But yeah sure I'll try again. By its a 93 4runner 3.0
Old Jul 11, 2017 | 01:18 PM
thook's Avatar
engine swap? hehe...extreme solution, i would say. unless you've just been looking for an excuse
there's other possible culprits. how'd you check the injectors for leakage? where'd you source your fuel pump? i've gotten lemons in the past and had to replace not long after installation. of course, the two i had probs with were china made shown to have probs in internet reviews. didn't learn that, though, until i had started having problems. anyhow, you replaced the temp sensor? with a new unit? brand?
Old Jul 22, 2017 | 06:51 PM
Armyross27's Avatar
Fixed it
got it fixed it was the #2 cylinder fuel injector, so i went to the wrecking yard got one and it worked so i went and bought all new stock denso injectors and had the intake and throttle body all cleaned and it runs good now. Also to answer about the temp sensor it was just a stock denso temp sensor, the fuel pump was delphi i had an airtex and went through 2 of them but its running good now
