Idle Speed Screw O-Ring Part Number Inside
Old Jul 9, 2017 | 06:07 PM
Thomas Reynolds's Avatar
Smile Idle Speed Screw O-Ring Part Number Inside
This is elusive o-ring part number for the idle speed screw on the 22RE: 90301-07001
The dealer will show that there is no separate part number for the oring as it only available through buying the entire throttle body HOWEVER due to a tip from another member on the forum I read it is the same oring size as the fuel injector orings. I had some leftover from sending my injectors to witch hunter performance last year (excellent service BTW!) as after he serviced my injectors he replaced all the hardware and shipped me back my old hardware. I tried one this weekend and it's perfect!
Old Jul 10, 2017 | 07:23 AM
Melrose 4r's Avatar
5 Year Member
Good intel!
For what it's worth, I was at HF yesterday and they offer a box set of metric or standard O-rings for a few bucks. i don't know if the right size is included but if it is you may be able to get that one, injectors and disti o-rings all in one kit.
