22re Upper Radiator Hose Diameter?
Old Aug 30, 2017 | 07:35 PM
GeoRoss's Avatar
I've been searching and searching and I can't find what the inner diameter of the upper radiator hose is. Any one know or have one they can measure for me?
Old Aug 30, 2017 | 08:26 PM
millball's Avatar
The Dayco #71262 spare I have is 1 and 5/16 inch inside diameter, near as I can measure.
Old Aug 31, 2017 | 09:56 AM
GeoRoss's Avatar
Perfect!
I'm assembling what I need to quickly install an aftermarket temp gauge and I'm going with the sandwich style in that upper radiator hose. Someday I'll relocate it near the OEM cluster temp gauge sender, but need it now.
Old Aug 31, 2017 | 12:21 PM
ewong's Avatar
Get a 22RTE thermostat outlet pipe
It has a temp probe fitting built into it
it measures the temp AFTER the thermo, not before, so its useful for seeing if the thermo is stuck.
In fact - its how I found out that in cold weather the thermostat "cycles" very few min or so - I can watch the temp swing up / down every time it opens...
Old Aug 31, 2017 | 01:23 PM
GeoRoss's Avatar
Are you talking about the thermostat housing? Mine already has a sender in it.
