1999 toyto tacoma
Old Jul 29, 2017 | 06:50 AM
mjs105's Avatar
1999 toyto tacoma
Truck cranks fine--however when you turn it off you cannot get the key out of the ignition. It stays in the on position. I unplug the battery so as not to drain it. Then I can get the key out of the ignition.
What do you think the problem may be
Old Jul 29, 2017 | 07:34 AM
mjs105's Avatar
Question 1999 toyto tacoma
Originally Posted by mjs105
Truck cranks fine--however when you turn it off you cannot get the key out of the ignition. It stays in the on position. I unplug the battery so as not to drain it--the alarm goes off, I'm having to do this every time I turn the truck off. It is aggravating and time consuming. Then I can get the key out of the ignition---hook the battery back up
I need 5 more characters to add to this message----@#$%^&*(
Old Jul 29, 2017 | 01:27 PM
wyoming9's Avatar
Red face
You are pushing the key in then turning all the way to the left.
To remove the key
It is such Muscle Memory I don`t think about it
If this does not allow you to remove the key.
You most likely have a Lock cylinder problem or a burr on the key.
Does flipping the key around make a difference??
distortedvoice
Oct 26, 2024 12:49 PM
Troy68
3.4 Swaps
24
Aug 14, 2017 06:14 PM
creekhunter
Jul 19, 2017 09:16 AM
jviers
Jul 18, 2017 03:30 PM
gryphonrunner
3.4 Swaps
Jun 30, 2017 06:43 PM
