Rear cam seal question
Old Jul 18, 2017 | 05:09 PM
Wesleyc_08's Avatar
Ok I have a real bad leak coming from my passenger side rear cam seal. After pulling off the cover and rear bearing cap then the plug with a mirror you can see a little hole that goes from the very bottom of where the seal sits all the way though back under the cams. Is this supposed to be plugged or open? We pushed a piece of wire through and it was plugged by some rtv.
