Checking Idle, Timing Advance - 22RE
Old Aug 13, 2017 | 09:12 AM
RAD4Runner's Avatar
I recently changed spark plugs, checked idle, timing advance and... helped save the Earth by keeping the MoreFunner out of the landfill and eliminating the carbon footprint of having to build another Prius-LOL!
The procedure I followed and tools I used for check/adjust my timing advance and idle on 22R-E:
Tools I used:
Timing Light and Tachometer combo.
Straight-slot screwdriver for idle adjustment
Jumper wire with 1/4-inch male spade on both ends for shorting "Check" connector (also useful for many other purposes).
12-mm 6-point box-end / combo wrench for adjusting distributor.
INSTRUCTIONS FROM FSM.
Before starting the procedure idle engine until it gets to normal operating temperature.
Check and adjust idle with AC off.
Proceed with timing / advance check with terminals T and E1 of "Check connector" shorted. Make sure you select the "4" cylinders for 22R-E.
I double-checked the idle RPM after the procedure, then back to timing advance, because I do not know if adjusting one would affect the other.
Old Aug 16, 2017 | 07:19 PM
L5wolvesf's Avatar
Good on you for posting up the basics. It seems like a significant number of people haven't learned these things.
I raise my glass (a Corona bottle to be precise) to you.
Old Aug 16, 2017 | 11:22 PM
Terrys87's Avatar
Great write up Ray. For others that have an 87 or newer the T/E1 connector is on the Passenger side Inner fender in a black box that you must jumper.
Old Aug 17, 2017 | 08:05 AM
coryc85's Avatar
Ray - nice writeup. I like that timing light with built in tach, I'll have to pick myself up one of those.
Old Aug 17, 2017 | 08:59 AM
RAD4Runner's Avatar
Tnx, Guys!
Will add details when I get the chance.
Originally Posted by coryc85
I like that timing light with built in tach..
Yeah, I don't have an SR5 cluster, and I don't wven know if a tach on the cluster is accurate enough for tune-up purposes, so got this one.
I wonder if those Auto-meter, equus, etc would be accurate enough.
Old Aug 17, 2017 | 02:35 PM
Co_94_PU's Avatar
Should be a trim pot on all of them, even you light one, with varied difficulty to access. Much like the factory gauges.
