Ac fuse location 93 4runner
Old Jul 16, 2017 | 01:25 PM
pplusent's Avatar
I have a 4x4 93 4runner 3.0 AT. Ac is not getting power to the ac clutch or fan. No power at ac switch or cut off relay. Fan blower etc. working fine, no light on switch. I see on the schematic there is a fuse before these items, but I can't find anything as to where it is! Anyone out there know where it's at? It's 108 + outside and ac would be nice!!
Old Jul 16, 2017 | 02:30 PM
wyoming9's Avatar
Red face
I can only say my 1992 4Runner it is on the right side above the Circuit Opening Relay
It has been a few years you need to pull the kick panel off .
Most times I have that whole lower section of the dash and glove box out as well
I can`t recall just what needs to be removed
Old Jul 16, 2017 | 04:17 PM
pplusent's Avatar
It should be a 10Amp fuse. The only one I see in that location is a 40 amp, but I will check again. Thanks
Old Jul 16, 2017 | 05:41 PM
pplusent's Avatar
I found it. All good now. For some reason that I will never understand it was in a covered box. Once I got the top off it was in plain site!
Thanks.
Old Jul 16, 2017 | 11:36 PM
wyoming9's Avatar
Has it ever worked maybe the fuse is missing from the block.
