- how come my 4runner is overheating???
- Newbie with a 93 SR5 4runner
- Difference between valve tick and timing chain???
- Gauge Cluster
- Looking at buying 4runner with blown HG
- 93truck 22re swap into 88 4 runner
- 94 Runner 3ZVE 25 code
- no oil pressure
- custom full metal high clearance front fenders.
- 1992 4wd engine rebuild errr....???
- losing the junkyard transmission gamble?
- 91 Toyota Pickup Upgrade
- aftermarket tachometer install video
- 1994 Pickup 3.0 - FREE - Worth it?
- can't adjust timing to 5 deg.
- Popping sound coming from drive line.
- where to find someone to do the Fox logo on my skid plate $$$
- ready to give up... bucking and high idle
- paint issues......need help!!!!
- New to me 92
- 95 4Runner lights on dash come on on start up
- What is this wire for??
- 2nd Gen 4Runner OEM Radiator Discontinued
- odd noise when down shifting??
- Power Steering Fluid Capacity???
- Toyota Tacoma v6 3.4l timing belt help
- A/T Oil Temp Light Condition
- New lift!
- Squeaky right front control bar!
- 3VZE wrist pin removal for noobs?
- Need some advice, please!!
- Can someone tell me whats going on here?
- Difference Between Models
- Lunchbox locker in LA?
- No Cut Zuk Mod 13" Springs
- 4.88 With 33s???
- 3.4 Vacuum line mystery
- 95 4runner auto skips 3rd gear
- NEED HELP. 94 Toyota 4runner 3.0 v6 auto.
- 3.0 to 3.4 Swap
- Help Adding AC to 93 Pickup 22re
- Lifting the 2WD Yota in 2014
- Need Advice on Truck
- How To: clutch bracket removal/repair/assembly w/ pictures!
- Speed
- 22RE Exhaust Leak @ Down Pipe Fixed
- HELP! Runs like crap after Ford relay installed
- Faulty temp gauge!
- Can't get that Timing Cover Off
- Found a 94 4x4 v6 that I may purchase but... it's auto. Worth it?
- Please Help 87 Toyota pick up
- to hot to handle vze 3.0
- 1988 3.0 oil leak
- Removing 19mm Cam Bolt
- How the hell does this happen: broken dist tower?
- 87 4Runner Gas Leak w/picture
- Fan clutch not working.
- 92 toyota pickup 3.0. Has no spark.
- Installing a Factory Roof Rack 2nd gen ( 94 ) 4runner
- 95 4runner engine temp
- 94 22re 2wd 5spd cant set timing help!!
- bobbed 95 4runner yes I have questions
- Leaky Transfer Case
- Anyone know where to buy 89 v6 a/c hose
- 22re engine fail SOS
- 95 4R 4WD issue.
- Seriously help me before i rage
- let me know what is missing because i need it
- Looking for turn signal to buy for an 1988 yota pickup
- Easy Question: Rear Wiper Blade
- 92 22re to 86 4runner need help!
- about ready to just part it out
- Aligning timing cover on 22RTE?
- Air condition question
- 91 Sr5 3.0 clutch question...(pressure plate size)
- Mangled Fusible Link (Battery to Fuse Box)....Temp Solution???
- Manual hub is jacked
- 88 4x4 22RE - Bad knock sensor? (Code 52)
- Best Oil for my car
- Mass Air Flow Sensor
- OME CS019R front bushing problem.
- 22r 32/36 run on issue?
- Got my OME CS019R's today
- shift lever seat problems
- Part 2 - head and head gasket or just timing chain and timing cover??? Help!!!!
- cel and engine stall
- 1995 3.0 4runner, spark, fuel, cranks for days!.. no start
- cooling system overpressurization
- 1988 4runner 3vze swap with a 1994 3vze. Help!!
- 91 4runner
- 88 4Runner keeps killing fuel pumps.
- Head lights problem
- Quick Question - CB Radio/Antenna Combo!
- Weber WOT bog
- just need confirmation!
- Looking for a good replacement fuel tank
- 3VZE Rebuild Issues
- Ticking after oil change (changed weight)...need urgent help!
- engine operating temp. on 89 3.0
- 1994 toyota pickup base need your help!
- funky AC smell? how to fix.
- What Is This Called?
- Pacesetter header
- 1993 Toyota Pickup Leaf Springs
- Best way to fix rust temporarily
- 22re idle problem or not.
- Where To Buy Front Hub Studs IFS?
- Need Help
- Fuel Filler Neck
- 1992 Manual 2wd 22re Into 1987 4Runner Automatic
- About to buy a somewhat built 88 sas'd 4runner
- Reading and clearing CEL codes
- Removing front diff '92 SR5
- 88 4 runner overheating 22re
- First Yota/ Trouble with tail gate
- Best Fuel Pump 94 3VZE
- 1993 4runner fuel pump maybe?????
- Pic request of underwood fuse panel
- Buying a 4 Runner
- Having trouble setting timing after tc replacement
- motor mounts
- HELP! Truck will not go in any gear!
- 22r egr leak?
- 1993 pickup won't run right.
- Good headgasket brand
- 1993 4runner code 14
- Rear Window Not Working with Key One Direction
- 94 22re rough idle then dies
- Leaves in in-cabin air box
- OME CS009R medium duty leaves too short on 93 pickup
- 1990 4runner 4wd not working (front diff grinding noises)
- just done 7mge maf swap
- 1993 pickup 3.0 auto tranny fluid dump when in 4x4
- The 5vzfe that could! (But won't)
- starter rebuild kit
- not sure where these go! PLEASE HELP!!!!!!
- Blown Head Gasket, What is my truck worth now?
- Coolant mixed with oil after timing chain job
- 3.0 heads nightmare
- Aussie Locker Install questions
- Gearing question for 89 4runner 5spd 3.4 swap
- ECT Power Light Troubleshoot
- dash board for 88 pick up expanded view - like in the manual
- ?? About ridge on driveshaft
- 93 Pickup Clutch Problem
- Radio/CB Radio Help?
- Cheap 95 4Runner Modifications?
- Engine control Board RIP
- harmonic balancer replacement gone wrong. 22re
- street outlaws
- Questions about zuk mod and shock length
- 22RE stalling
- Gas gauge problem
- Cam or no cam ?
- Mystery Clunking???
- W56-B Transmission rebuild or replacement?
- How does a '3L' stack up against a 22R-E?
- 92 truck vibrates real bad when stopped in gear
- 1994 extended cab swap
- Flushing Transmission/ power steering 92 Pickup
- brake junction box? prop valve ??
- 87 22R A/T wont shift 3 / O/D
- Electrionic VSS sending unit
- How to Disconnect TPS Connector from TPS Sensor?(1986 22R-E)
- 95 4Runner Tire Help?
- Tranny issues
- Wanting To Make My 95 4Runner Big!?
- 92 pick up 4wd 4cylndr wont start
- oil cooler gaskets
- New 4Runner And Need Help!
- Need help!!! noise coming from around distributor 88 3.0 4runner
- 7 mge swap can standard v6 air box be used
- Rear diff rebuild
- 89 Factory AC questions
- Any ideas on this noise?
- EGR (California)
- Swapping 92 22RE for 88 22RE Trouble
- Help with what I need for rear disc conversion
- alternator and fuel gauge issue ! need help !
- Hole at base of carburetor?
- Best price on gears
- 1993 Yota 4x4 22-RE Timing Chain Replacement
- low idle
- Payload of '94 Toyota Pickup (Slide in Campers)
- '86 yota 4x4 22r - head gasket - new head or new engine ??????
- Need major HELP!! 1990 3.0 won't start
- 87 22R 4x4 wouldn't start this morning...
- 1992 22re Distributor/Timing Help
- Visual Differences in Camshafts?
- Wheel Bearing Parts
- 89 4Runner Problems
- 1987 4runner 22RE help!!!!
- Oil leak!!
- random bucking after on E
- 12 Degrees Advanced....and its Awesome!!
- Messed Up Oil Pan Gasket, Now it Leaks. How to do it Right?
- Distributor Cap and Rotor fitting issue
- Oil and heat guage wire locations
- A/C Clutch going out?
- 22RE Cracked Head at EGR Plate
- Fuel puddled in Throttle body & takes a couple tries to start from a cold start.
- control arms
- Hard to start 4runner
- 1993 22R-E with a weird hot start problem . . .
- Driver's door the same???
- 1988 22re pickup hot start issue
- ISR mod pros/con
- I may have messses something up please help.
- Water Pump Replaced still leaking 22RE
- Odd ball rear leaf springs for specific vin #'s?
- 22re Chugs When You Start Driving
- AC H/L Pressures
- 1991 22re 4x4 will not engage or show on dash
- 1993 manual transmission
- Problem with blower
- Do NOT buy Depo Fan Shroud (This is a Public Service Announcement)
- 87 Toyota 4x4 parts
- * Supra AFM problems *
- This Clutch is completely stuck
- High HC, Norm CO, High NO (Another smog thread)...need help!
- '90 4Runner Engine rebuild or swap?
- Bed Subframe build
- Help me here..
- Stereo Deck Install, and Front bumper reinforcement question.
- Brake Pedal Free Play....Adjustment ???'s
- Bad temp sensor or gauge?
- Is repair of ignition cylinder possible?
- Newbie with some problems!!!
- Hesitation on Acceleration - Cold 22re
- Drive shaft snapped
- Brake booster, abs or no abs difference?
- No Fast Idle at Startup....Ideas???
- 22r will not idle below 3,400 rpm.
- synthetic oil and the 22RE
- gapless spark plugs?
- High Mileage Oil question
- 86 22re always needs gas to start running
- Is this wire in the right spot?
- EFI Kill Switch
- Does the starter have to be disconnected to remove the engine from the trans?
- Grinding noise
- Trick to removing the two rear cargo nets from 88 pickup?
- 22re pulley movement?
- Windshield Rust Fix! 1993 Pickup
- 22RE gas path
- 94 pickup 4 cyl 22re ac?
- High HC on emissions after tune-up 87 22RE 4runner
- Anyone have a All Pro Expedition Series Pack Rack?
