22RE gas path
Old Jul 11, 2014 | 05:36 PM
dabineri's Avatar
22RE gas path
The gas line from the tank seems to come to the fuel filter and then into the fuel rail. The fuel pressure regulator bolts right onto the fuel rail and the injectors are connected to the fuel rail.
I am having difficulty seeing the path of the gas so that the regulator actually controls the pressure to the injectors.
Are there some separate passages within the fuel rail.
Can someone explain? Thanks, Dave
Old Jul 12, 2014 | 10:27 PM
wyoming9's Avatar
Red face
The way it works is your fuel return line is connected to the fuel pressure regulator. When fuel pressure gets to high it opens
Hard to explain without looking at a fuel rail it has been awhile
Old Jul 13, 2014 | 05:04 AM
dabineri's Avatar
Fuel Pump on RE22
Thanks, Wyoming9 that's what I figured and just needed to confirm.
I have determined that the check valve on my fuel pump is bad. Rail pressure drops to zero immediately when engine is turned off. Also watched the fuel pressure after pressurizing, pinching supply fuel line and return line (engine off) and then releasing flow in the supply line and pressure drops to zero immediately
What symptoms is a bad check valve likely to show?
Thanks,
Dave
Old Jul 13, 2014 | 06:40 AM
wyoming9's Avatar
Red face
Pretty much what your seeing .
Unless you have a external leak then you should be able to see the leak..
Old Jul 13, 2014 | 06:49 AM
dabineri's Avatar
I thought that the check valve would just let it drain back into the tank instead of maintaining pressure. No leaks. Dave
Charecter1
Nov 6, 2023 10:08 AM
skoti89
Sep 11, 2015 07:46 AM
pyramid
Jul 30, 2015 10:05 AM
daddio
Jul 18, 2015 10:20 AM
ryerye13
Jul 14, 2015 08:27 AM
