Does the starter have to be disconnected to remove the engine from the trans?
Old Jul 12, 2014 | 02:42 PM
85yota_prerunner's Avatar
PLEASE HELP!!!!!!
I have a 95 4runner that I am trying to take the engine out I have already got the heads off, all the tranny bolts taken out and motor mounts undone. Do I need to take off the starter too??? And is there a certain gear the trans has to be in to disconnect the engine from the trans??
Old Jul 12, 2014 | 02:57 PM
JonnyBoy's Avatar
Yes, the starter has to be removed. The wires going to it are part of the engine harness, for one, and will be in the way if not being removed with the engine anyhow, and the bolts go through the engine block to the bellhousing, holding them together. Neutral is probably the easiest for removing the engine, but probably isn't critical. Just gives a little bit extra play to help with the clutch/flexplate from hanging up.
maddad4x4's Avatar
Yes you need to remove starter.
Old Jul 12, 2014 | 03:05 PM
Okay Thanks!!
Old Jul 12, 2014 | 10:20 PM
wyoming9's Avatar
Red face
Then know it takes a some prying to get them apart if it has been awhile.
smthwsn357
May 1, 2024 07:28 AM
kazuya2416
Apr 5, 2024 02:17 AM
icentropy
Sep 16, 2020 02:47 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
