Rear diff rebuild
Old Jul 19, 2014 | 04:03 AM
mistyg7's Avatar
Rear diff rebuild
So I am rebuilding my whole rear on my 91 pickup v6 4x4 and the rear gear ratio on my truck is 4.10 (41 and 10 teeth) and apparently they don't make those exact gears after market. I was told by a few aftermarket companies that the 4.11 with (38 and 9) is interchangeable with the orginal one that came with my truck. I would really appreciate any feed back before I go through with this thanks!
Old Jul 19, 2014 | 04:21 AM
RJR's Avatar
RJR
38/9 equals 4.2222, which probably won't work. Assuming you meant 37/9=4.11111, I would think the difference between that and 4.10 would be negligible, equiivalent to less than 0.1 inch difference in tire diameter front to rear. You probably have that already if your tires aren't brand new.
Old Jul 19, 2014 | 04:28 AM
mistyg7's Avatar
RJR u r correct w the number of teeth thanks! My tires r pretty new though what does that mean?
Old Jul 19, 2014 | 07:10 PM
rattlewagon's Avatar
you can get 4.10s all over the place...
http://www.summitracing.com/search/p...odel/toyota-v6
Old Jul 20, 2014 | 07:22 AM
Gevo's Avatar
Since you are re-building it, have you thought about gearing it down for larger tires/offroading? You would have to do the front gearing as well of course.
just a thought.
Old Jul 20, 2014 | 01:27 PM
vasinvictor's Avatar
You can pick up a whole third with 4.10s for $50. I have a spare on in my shop that I can't be bothered to ship because it's just not worth the shipping. Check out the trucks being parted out in the classified section. I've cracked diffs from 200k mile trucks and the gears looked excellent.
bigjstang
Jun 2, 2025 03:56 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
scottyg486
Jul 19, 2015 05:34 PM
Vargntucson
Jul 4, 2015 12:15 PM
