PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 [164] 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266
  1. Diagnostic Trouble. Odd codes?
  2. Replacement axleshaft
  3. 3.0 extended crank
  4. I need good news- Headgasket?
  5. 1st gen 4runner roof rack weight
  6. 93 fourrunner engine help
  7. '92 Pickup pulling left when braking
  8. Warn Trans4mer for Tacoma - Will it fit
  9. Poser Pics and some questions...
  10. Engine stumbles and misfires. Why is it doing this?!
  11. 22RE problem
  12. Sold my 88 3.0, picked up a 22re
  13. starting woes
  14. Emisions Help
  15. New Toyota Owner Wants Suggestions, Gears? True Trac?
  16. Buying a used locker: good or bad idea?
  17. some questions about inclines and manual trans.
  18. Need help with Vacuum hoses on 22re
  19. Guide to remove 4runner 1993 front bumper?
  20. Code 11
  21. rattle can flat black paintjob
  22. Having a stuttering/hesitation problem, can't seem to solve..
  23. looking for a 93 v6 front bumper (4runner)
  24. My new rear bumper *pics*
  25. Thermagasket test results
  26. My new 89 runner
  27. CV joint bolt question?
  28. rear differential is leaking from the front seal - pinion seal
  29. Knock sensor
  30. Truck only starts sometimes
  31. knock sensor...
  32. brake and charge light are on
  33. 22re RPM drop
  34. HELP ! Check engine light!
  35. whirring sound
  36. Quik survey: rear springs on your 86-89 4runner ONLY
  37. 7'' trail gear springs
  38. 87 pickup rear tire carrier
  39. 1st Gen 4runner Full Top :D
  40. Rear window switch in console not working properly
  41. Engine is stalling please help
  42. 22R Front Seal replacement
  43. 3vze increase fuel economy?
  44. Rough idle
  45. Aftermarket steering wheel
  46. Clutch noise
  47. shock questions
  48. 22re coolant in exhaust help
  49. Belts squeak under load
  50. Custom cab? Extended cab? What the hell was it? I want one...
  51. Can I swap a 4wd engine and tranny with a 2wd tranny and engine
  52. Where is the 3VZE EGR Blockoff thread?
  53. 94 4Runner Auto Rebuild or Swap 3VZE
  54. no power to the ignition
  55. 3.0 rebuild complete
  56. shameless pics of my topless baby and her new tattoo.
  57. Need help with idle problem
  58. should i paint my tail lights?
  59. 87-88 4runner as a daily driver?
  60. cargo lighting 89 4runner upgrades?
  61. I know Grill Post
  62. 4runner 3.0 running rough, please help!!!!!!!
  63. Rear window relay temp fix
  64. What is this part on the intake?
  65. The 4Runner owns Samurais
  66. Why does my truck not have these features?
  67. Fuel Pump
  68. 22r Head gasket leak
  69. All Pro or Rocky Road
  70. That one oil pump bolt.....
  71. 22re Engine Pinging Discussion
  72. Speedometer drops and loses power???
  73. Power Steering box issue
  74. Electrical Problem. Need help.
  75. 93 with bigger plug wires (8.5's)
  76. Rusty Muff
  77. hey!
  78. Shifter seat, etc.
  79. Quick 5speed swap question about speedo
  80. Rear diff rebuild
  81. Vaccum leak spewing oil? Help!
  82. low and spratic oil pressure???
  83. identify this part please, tracking oil leak
  84. toyota camry v6???
  85. Cast crank for 22re?
  86. Wreck - front corner / bumper damage
  87. One Spark and then......Nothing
  88. 1st gen gas leak / fuel pump bracket
  89. Egads! Motor may be out? engine started running hot
  90. steering gear box interchangable????????
  91. 1986 22R Fuel Pump Problem
  92. squeeling sound from engine pls help!
  93. missing a part for my lift.....do i NEED it?
  94. can't seem to find ADD to manual conversion kit anywhere....
  95. Valve Clearance Question 3.0
  96. New Clutch Need or What
  97. air in cooling system = sudden coolant loss?
  98. Homebrew light bar?
  99. Finally buying my 4runner
  100. 92 4runner sr5 v6 3.0 2wd to 4wd conversion possible?
  101. Anybody parting out a 3VZ
  102. having one hell of a time removing L control arm.
  103. 3.0 head bolts or ARP studs?
  104. Please help won't start
  105. Disable rear ABS light?
  106. Will front revolver shackles work?
  107. Nissan Manual hubs
  108. Timing chain kit???
  109. broken 22re timing chain guides
  110. 30 mph collision pics! You all wanted to see them.
  111. 3.0 cam advance?
  112. Deavers or 4-link rear
  113. Speedo Cable Squeal
  114. Gear driven case shifter not moving are tcase removed
  115. 91 V6 Toyota Pickup Clutch Problem
  116. Auto to man trans swap help (1st gen)
  117. 1990 4runner OverDrive Not there
  118. Need input, coolant leak...
  119. Alternator or battery? (or something else?)
  120. flowmaster help?
  121. I need A/C
  122. Sealing front hubs? ideas...suggestions?
  123. ac compressor question
  124. brake fluid reservoir and the master cylinder seals?
  125. Changed knock wire won't run!
  126. Another kayline question
  127. Easy Gas Cap Question
  128. stereo mounting brackets?
  129. Hitch from a Runner to a Pickup
  130. $500 parts truck
  131. all the anti freeze was in the tank on the right and over flowing
  132. TRD Front LSD Locker
  133. burnt clutch? ... or someting else
  134. o2 sensor connection
  135. 8" Locker ?
  136. trouble code 42....
  137. 22RE engine rebuild questions
  138. 93 wont start just turns over and over (3VZE)
  139. What seats will interchange?
  140. Quick question about the pinion flange nut..
  141. shifter seat bushing replacement. WOW!
  142. Cone conversion parts
  143. new thirds
  144. 3.0 '94 starter on '88
  145. 22RE REALLY hard to start cold
  146. "more" ifs lift help
  147. need the paint code for a maroon 2nd gen runner
  148. Great Snorkel option -with pictures
  149. head gasket replaced... blown after 500km?
  150. 1st gen 4runner sail panel removal
  151. 88 runner, help me make it poppin
  152. Looking for write-up on an automatic to manual swap for the 3.0
  153. lc engineering 3vz stuff
  154. quick little Q on rear-view mirrors/dome lights / 3rd gen PU and 2nd gen 4Runners
  155. My 86 Toyota 4runner video of noises and issues.
  156. I will finally own a 2nd Gen 4Runner
  157. Trouble with my 86' 22rtec pickup
  158. Jumpy temp guage... beats me.
  159. are all pitman arms equal??
  160. Timing chain or rod bearing? You tell me.
  161. my crappy paintjob
  162. HELP!! Timing belt install
  163. 2wd auto-manual tranny swap
  164. $500 to install body lift?
  165. I wrecked the Yota, 30mph head on into a telephone pole :o(
  166. 88 4runner tailgate guts
  167. Anyone have 22r rebuild photos?
  168. 88 4runner license plate lights
  169. Charcoal Canister.. please explain
  170. 94' pickup rear window.. What fits?
  171. Breaking into my own 89 runner
  172. Charge light and P-Brake light on - 22R
  173. 94 3.0 code reader?
  174. 91 22re stumbles and dies while driving
  175. Finally installed ball joint spacers and coil spacers
  176. 22re wont run :(
  177. exhaust question
  178. intake????
  179. Now this is a wierd electrical problem!!
  180. Fuel line question
  181. Need 3.0 and tranny for my 95 4runner
  182. 3.0L No Fast Restart
  183. TG rear bumper
  184. Fuel/Air Mix Question?
  185. Evap/charcoal canister alternatives
  186. anyone familiar with the 3.0 internals help me out
  187. 93 4Runner/ General Advise
  188. Need help on brake drum return spring
  189. rear drive shaft "ping sound"
  190. 165k miles, original timing chain. replace?
  191. Oil Pressure Gauge
  192. Lighting Question
  193. Frame Specs?
  194. 4runner problems-Oil leak and AC
  195. 1st gen 4runner running boards with lights; how much are they worth?
  196. 22rte swap problems: 22RTE wiring harness and 22re cab harness??
  197. no dash lights
  198. A340F delayed 1-2 shift when cold??
  199. 20 year old recall consumated")
  200. Head gasket lament
  201. Electrical problem - Please help
  202. Factory 4:88 Question
  203. Anyone running 63's and IFS?
  204. v6 blown hg, driving distances?
  205. 87 pickup 22r
  206. Mystery ground wire on Radiator support.
  207. Speaker Placement Idea
  208. Cheapest and Best way to get my truck running again
  209. Help Me Identify This Bracket
  210. 5spd vacuum line help
  211. 22RE engine questions for rebuild?
  212. swapping a 22re in place of 22r
  213. 83/84 yota, or 85 yota or 90 4 runner
  214. Over-boosted steering
  215. Air Cleaner System
  216. quick disconnect door hinges?
  217. Fan clutch and starter for an '88 22R
  218. 87 4runner header and mods?
  219. 85 leafs in a 94?
  220. quick gearing question??
  221. Need help cleanin the Diesel out of my 3vze
  222. Look what i broke after driving 1,100 Miles...
  223. Fan Idler pulley: To replace or not to replace?-that is the question
  224. Grill help
  225. rock assault axle housing
  226. Power Steering Help?
  227. Ball Joint Spacer Install Questions
  228. loss of torque
  229. Electric Speedo Odometer change- SR5 Swap
  230. 1100miles trip went very well!!!!
  231. Smoking engine bay after HG replacement
  232. Mystery coolent leak.
  233. need sensor!! 89 efi
  234. dana 60 full width front 3 or 4 link ?'s
  235. blinking battery brake light - Alt Ground Issue?
  236. 94 valve covers-is it hard?
  237. 94 valve covers-is it hard?
  238. Radio woes, today was a pain.
  239. 4runner resists turning when in 4wd
  240. question about shocks....
  241. harmonic balancer bolt
  242. help - need Wiring Diagrams
  243. whats bad in my front end!!?? axleshaft support bearings?
  244. Missing Throttle Return Spring
  245. Rod directions
  246. 95 Pickup fuel tank
  247. 93 toyota wont start
  248. hub nut??
  249. Bleeding brakes on a rear ABS system
  250. Finally got another Yota
