Factory 4:88 Question
Old Apr 21, 2009 | 01:07 AM
91 4Runner's Avatar
Ok, I was at the local pick'n'pull yesterday, and there is a 4Runner in there with an axle code of G144 - so 4:88. My question is will the Yukon Gear Spool I have (bought for my factory 4:10 carrier) fit in a 4:88 carrier?
Thanks for any help!
Larry
Old Apr 21, 2009 | 04:51 AM
91 4Runner's Avatar
Bump I'm sure someone knows! Zuk?
Old Apr 21, 2009 | 05:01 AM
Wardamneagle's Avatar
This link might help you with that question:
http://home.4x4wire.com/erik/diffs/
Old Apr 21, 2009 | 07:03 AM
ZUK's Avatar
ZUK
Yes....the spool will fit just fine. It's the "usual thick ring and pinions" that won't. So bolt the 488 thin gear onto the spool,swap the carrier bearings over, and set your BL to about .006~.008" and put about 100 ft/lbs of torque on the adjuster wheels for proper CBPL and you're all set.
edit- You might think about sending the spool and G144 3rd to me....let me set it to spec. I can replace the seal at the same time. Might even make a link of it and add it to my webpage.
Old Apr 21, 2009 | 01:03 PM
91 4Runner's Avatar
First off, thanks for all the help! I guess I'm gonna get some 4:88!
Thanks Zuk for reafirming my suspisions! And I'd really like to send them to you, if you'd like to pay shipping both ways! J/K I'd really love to but shipping would kill me. !'ll let a local speed shop do it for me! Thanks again!
Larry
Old Apr 21, 2009 | 01:12 PM
DeathCougar's Avatar
Zuk comes highly recommended. I would suggest sending it to him
Old Apr 21, 2009 | 02:29 PM
ZUK's Avatar
ZUK
You have a point there....I just noticed you are in Canada I did one for Canada and with the duty taxes it worked out to 120 USD for me to send it back to him....that is pricey ....and multiply that times 2. It was a thought anyways. ZUK
Old Apr 21, 2009 | 11:09 PM
91 4Runner's Avatar
I certainly would send it if it wasn't so expensive, but I can get it done here for $140.00. Cannot wait!
Old Apr 22, 2009 | 12:13 AM
Matt16's Avatar
Zuk's page tells you how to do it, and I've got a writeup floating around yotatech (doesn't cover removing the bearings though). If you can borrow the tools, I suggest you do it yourself, resetting backlash is not hard, it will take you maybe half an hour the first time.
Old Apr 22, 2009 | 02:23 AM
91 4Runner's Avatar
We'll see. Maybe I will tackle this myself!
colasurdo
Jan 11, 2026 08:10 AM
bigjstang
Jun 2, 2025 03:56 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
skebe22RTE
Jul 31, 2015 02:03 PM
88yodabasket
Jul 13, 2015 01:32 PM
