rear drive shaft "ping sound"
ok so i have a 1990 4x4 toyota pickup
when i take off on first gear it sometimes does this loud "ping" sound
and it rarely does it on second gear. i was wondering if i buy a new drive shaft will that noise stop? i already greased all that needs to be greased on the driveshafts etc.. idk what else to do..
U-joint, or excessive backlash in the rear diff. The "ping" sound resonates through the hollow driveshaft, which makes it sound louder. If you take a hammer and tap the driveshaft, you'll probably hear the same sound. You just have to figure out the source of the clunk that causes that resonating ping sound. Check the flanges on the rear diff and transfer case (where the driveshaft bolts onto) for looseness, and check for a lot of rotational play of the driveshaft with the tranny in neutral and the rear wheels on the ground (that would signify excessive backlash in your rear diff).
Don't spend the money on a new driveshaft. That's not likely your problem (unless there is excessive rotational play within your slipjoint... which would also likely lead to vibration at high speed, so you'd know if you had that problem).
Jun 1, 2021 01:51 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
icentropy
Jul 11, 2015 07:21 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
