whirring sound
Old Apr 28, 2009 | 05:54 AM
wilshire's Avatar
whirring sound
Resolved: It was the pinion bearing in the rear differential. Fixed by swapping in a used 3rd member.
I've noticed that my truck is making this sound.
I'd describe it as a vaguely metallic whirring or whooshing sort of sound.
It only does it when i am in gear but not on the gas. If the clutch is disengaged, it doesn't make the sound. If I give it gas, it doesn't make the sound (as far as I can tell. It's possible that other, normal engine noise drowns it out when I gas it, but I don't think it's the case).
I can't pinpoint the sound because I have to be in motion in order to hear it.
I have a 1990 pickup, 4wd, manual trans, 22RE.
What could this be?
Old May 11, 2009 | 04:06 PM
wilshire's Avatar
Does this sound like it could be my input shaft bearing?
Old May 11, 2009 | 04:10 PM
yoterr's Avatar
good possibility, how bads your clutch? lol might as well change er out if you gotta change the imput shaft bearing
Old May 11, 2009 | 04:13 PM
wilshire's Avatar
The clutch is great. Previous owner says it was changed around 20k miles ago and I believe him.
Old May 11, 2009 | 04:18 PM
yoterr's Avatar
well it deff sounds like an imput shaft bearing to me, but maybe some1 els will chime in, but to get it changed out you basically have to do the same thing as change the clutch, (why i was asking)
Old May 11, 2009 | 04:34 PM
bmxmike's Avatar
mine does the same thing in my 89 pickup sr5 4wd when im at low speed and when im turning
Davebarbier
Nov 3, 2015 03:28 PM
Kamaloha
Oct 16, 2015 05:13 PM
Chicken12
Oct 14, 2015 03:54 PM
Flightguy
Oct 2, 2015 05:34 PM
voiddweller
Sep 28, 2015 11:21 PM
