air in cooling system = sudden coolant loss?
Theoretically it is possible to have an air bubble in the system and the coolant to appear full then suddenly empty. Bubble stuck at a high point in the system, eventually works its way to the rad cap (another high point) where it is forced out the the system by the pressure in the system through the cap and into the overflow (not airtight seal) and escape. The engine cools off and sucks the remaining overflow coolant back into the system leaving it empty and the driver very puzzled... right?
Almost certain it is not the HG as i did that carefully a little over a year ago and the exhaust doesn't smell sweet, no steam etc... Might be a leak, there are still several hoses that are probably original, just I have my doubts they would allow the escape of a little of fluid in 15-30 miles. Its done this before after I've messed with the cooling system. 'll have a better look tmr.
By the way, I don't know if it was by design or fluke, but I LOVE how the heater core "gurgles" at me when the coolant is low. Lets me know I have to check it.
The only way I see that possibility happen is just after working on the cooling system, where you had to drain and fill the radiator. But if you havent' done any recent work on it.. then i'd say you have a slow leak. Try to get your hands on a coolant pressure tester. good luck.
Also, I've got no white smoke and the exhaust smells like it usually does. Oil is not milky either. My guess is air in the system.
I refilled the rad and reserve and drove 60km (35mi) today. Didn't use a drop of coolant aside from when I kept checking for bubbles by opening the cap when the engine was hot and the truck was facing uphil. I think its pretty well burped by now.
the1998sr5
15
Jul 14, 2020 08:35 PM
Avenged
Jul 9, 2015 07:55 AM
