93 fourrunner engine help
Old Apr 29, 2009 | 08:10 AM
Hitoyota84's Avatar
Hi, I need some engine advise for my 93 Fourrunner. It has 231,000 miles on it. In the past month or so it started running rough in drive, not so much in park. I changed the cap, rotor, and spark plugs (they were in bad shape) and the air intake tube it was cracked. It seems just a little better but still has that shake to it. Any ideas what I can try next?? Thanks. Lisa
Old Apr 29, 2009 | 08:12 AM
DeathCougar's Avatar
Air intake tube is cracked....did you replace it? If not, do that. Its letting unmetered air into the intake.
Old Apr 29, 2009 | 08:16 AM
Hitoyota84's Avatar
Yes that was the first thing I tried. Put a new one on. I havent replaced the wires yet, they want 100 bucks for factory ones. I hear the aftermarket ones are dificult to put on.
Old Apr 29, 2009 | 08:17 AM
Hitoyota84's Avatar
I replaced the head gasket over a year ago. But before that went it ran great, so I dont think that would be a symptom for the head gasket going again.
Old Apr 29, 2009 | 08:44 AM
TNRabbit's Avatar
If you've never replaced the O2 sensor, it's past due.
Also, you can get the O2 sensor & NGK spark plug wires (very good) at www.sparkplugs.com
Old Apr 29, 2009 | 09:02 AM
Hitoyota84's Avatar
Wouldnt my idiot engine light go on if the sensor was going bad?
Old Apr 29, 2009 | 09:06 AM
904_runner's Avatar
Possible, but not always..
Its good practice to change it every so many thousand miles. (not sure how many)
I got a denso one from napa. I cant remember exactly but i think it was near $80
Old Apr 29, 2009 | 09:21 AM
Lummpus's Avatar
What engine is in it?
Old Apr 29, 2009 | 09:35 AM
3.0l V6
Old Apr 29, 2009 | 09:38 AM
TOYOTA 1's Avatar
id start with a basic tune up, plugs, wires, etc..
Old Apr 29, 2009 | 10:16 AM
TNRabbit's Avatar
Like I said, if you've never changed the O2 sensor, it will improve the performance & economy with that many miles on the engine.
Old Apr 29, 2009 | 11:50 AM
Hitoyota84's Avatar
I have put about 70,000 mile on it since I purchased it. It has a V6 in it and I have only had to change to oil and head gasket since I bought it.
It has been very good to me. I want to try and fix it so she lasts a while....
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
