Code 11
Old Apr 28, 2009 | 02:54 PM
854x4's Avatar
Code 11
I have a 86 4x4 truck with a 22re and when I jump the timing connector my timing does not change? I checked it for codes and found a code 11 from reading this points to the tps or the computer. Would this code keep it from changing time when I jump the connector?
Old Apr 28, 2009 | 03:48 PM
toyota4x4907's Avatar
1986 22re code 11-- Throttle switch signal to Electronic Control Unit (ECU) is OFF during diagnostic check-- Defective TPS circuit, TPS, or ECU.
Old Apr 29, 2009 | 12:32 PM
854x4's Avatar
I found my answer on 4crawlers website. The code 11 keeps the timing from changing when you jump the connector but it doesent matter now the headgasket blew(water in oil) so I will be rebuilding the motor next week. It has 260,xxx miles so its time.
Old Apr 29, 2009 | 12:45 PM
Oh that sucks! Good luck with the rebuild.
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
