3.0 extended crank
Old Apr 29, 2009 | 09:38 AM
Joebeau's Avatar
3.0 extended crank
Hey guys got a problem. Its a 93 pickup 4wd and the head gaskets are fine. The truck has to crank for 20-30 seconds when its cold stutters and then smooths out. But if its just warmed up it starts up perfect, IE shut it off and restart immediatly. If you let it sit and idle for an extended time it will start to misfire, or if you park the truck say 10-15 min it starts rough and idles rough some times it won't start. But if you can get it on the road it eventually smooths out. I think its some sort of heat soak issue but what. It has new cap,rotor,plugs,wires,ect,maf,coil,ignition module,O2,fuel filter, and it still does this. Please help.
Old Apr 29, 2009 | 09:49 AM
894x4pickup's Avatar
Cold start injector.
Old Apr 29, 2009 | 09:58 AM
Joebeau's Avatar
But why would it cause it to start missing while at idle?
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
ksmudrunner99
Jul 21, 2015 05:33 AM
CanRunner
Jul 20, 2015 01:29 PM
redneck17
Jul 17, 2015 07:44 PM
ZONAYODA
Jul 13, 2015 07:17 PM
