Cast crank for 22re?
Old Apr 25, 2009 | 04:29 PM
PlugItIn's Avatar
Do you think a cast crank will be fine for my rebuild? You can find a new cast crank for $150ish. I think i could have my stock crank turned, but then i would have to get oversized bearings (already have standard size bearings). How much does getting your crank turned usually cost? Thanks in advance!
Old Apr 26, 2009 | 11:21 AM
Dirt Driver's Avatar
I would guess it to be $80-100 for a regrind plus probably ~$60 for a name brand bearing set.
The stock crank is forged, right? I personally would keep it. I don't think a cast crank will be a problem for even 500bhp(Ford 2300s have gone in excess of 700rwhp on the stock nodular crank), but I doubt you could even worry a forging, let alone break it at street power levels in a 22R-E.
Old Apr 26, 2009 | 11:27 AM
TOYOTA 1's Avatar
yea around 100 for a regrind. i have built a couple stock 22re's with aftermarket cranks, no problems here.
Old Apr 26, 2009 | 11:44 AM
I wouldn't worry about using one in a stock 115hp engine, but I assumed it was for the turbo 4Runner....
Old Apr 26, 2009 | 12:02 PM
Flash319's Avatar
I would just get it re-ground. Best to stay with Toyota parts.
sandyota
Feb 4, 2021 11:16 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
CanRunner
Jul 20, 2015 01:29 PM
redneck17
Jul 17, 2015 07:44 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
